Use serial port to read integer value
With an Arduino Elegoo Uno R3, I am running a Shift Register (74HC595) and a 7 segment common cathode 4 digit display.
I need to use the Serial port to read an integer value. The range of numbers is [0,9999]. I need to display the value on the seven segment display.
I have this starter code that is cycling values on the 7 segment display, but I need to do more with it preferably with arrays and most importantly using the serial port to read an integer value.
/www.elegoo.com
//2016.12.12
int latch=9; //74HC595 pin 9 STCP
int clock=10; //74HC595 pin 10 SHCP
int data=8; //74HC595 pin 8 DS
unsigned char table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c
,0x39,0x5e,0x79,0x71,0x00};
pinMode(latch,OUTPUT);
pinMode(clock,OUTPUT);
pinMode(data,OUTPUT);
void Display(unsigned char num)
digitalWrite(latch,LOW);
shiftOut(data,clock,MSBFIRST,table[num]);
digitalWrite(latch,HIGH);
Display(1);
Display(2);
Display(3);
Display(4);
Display(5);
Display(6);
Display(7);
Display(8);
Display(9);
Display(10);
Display(11);
Display(12);
Display(13);
Display(14);
Display(15);
Below is a screen shot link of the bread board schematic.
