Use two TP4056 to charge lipo 2s?
basically what the title says, I want to build a portable lipo charger for 2s batteries, put together this diagram so that you understand what I want to do, from what I understand, it should charge the cells well up to 4.2v individually
What I want to do is a mini portable charger for 2 2s batteries using a total of 4 TP4056 (2 for each battery), and an arduino to display the individual cells on a screen, I know that this module has overload protection
A link to the data sheet of your modules is required.
I think that you will produce short circuits with stacked batteries. Better separate the batteries and load them individually.
Those TP4056 modules are real cheap for sure and have been around for a long time.
But the TP4056 IC is specifically for charging a single Lithium cell, its not designed to charge a string of lithium batteries in series.
What is the input voltage you were using to charge the 2S array ?
They are 3.7v batteries, they are high discharge drone batteries, I am attaching a photo as an example of one I have
That would be impossible, they are batteries for drones
No. That circuit would produce direct shorts across the cells. You need an official 2S charger, something like a TP5100 module. But I think you would need high charging voltage for that, maybe 10-12V, not just USB 5V.
Two TP4056 might be possible is two completely separate power supplies are used.
This module for a 2S pack should be easier.
Note that it needs >8.8volt to charge a 2S pack. 12volt would be ok.
Leo..
I use this model to load 2 cells.
Your 2s charger does no balancing :slight_smile:
With that module I can't load it in a balanced way, right?
Do you know the bms HX-2S-01? I suppose it could be useful for what I want to do, right? I imagine that it will work well to charge the batteries of 2s drones and will cut at 4.2v
If I used an HX-2S-01, I could charge the 2s drone batteries, right? They are delicate batteries from what I know, I don't know if that module will help me to charge
