Using a Eufy 11s Vacuum Brushless motor
Hi
I have removed the vacuum unit from a Eufy 11s robo vacuum cleaner. I want to repurpose the vacuum but I'm not sure how to drive the motor. I understand that brushless motors require a brushless ECS but I see that this motor has a board attached to it so I'm wondering if that is actually the control board for the motor or not. Also, the motor, as you can see in the screenshot has 4 wires coming out of it but I'm not sure which wires I'd need to connect for power, ground etc.
Alternatively, I've tried removing the motor so that I can inspect it more closely and possibly swap it out for a brushed motor but it is stuck on and I've so far been unable to remove it.
Any help with getting this motor running or at least pointing me in the right direction would be appreciate.
Alternatively, some tips on how I can remove the motor would also be helpful.
Thank you
Are you confusing the motor for the brushes (brush motor) with brushed motor (uses carbon brush blocks)?
Download the service manual it will give you a lot of the information you will need.
I can't find the service manual, so I need to figure it out manually.
I'm not sure I understand what you mean. This is a brushless motor with four wires so I'm assuming that it is a three phase motor with perhaps a HAL sensor on it. However I don't know which wire is ground, which is the HAL sensor, if any, and finally which ones are for current.
Any idea where I might find it?
This is the closest I could find to information on the motor
Doesn't a three-phase brushless motor have nine wires? Three for phase, three for HAL sense, 5vdc, ground and temperature.
The number of wires depends on what type of motor it is. There are millions of 3 phase motors without brushes or sensors. They are called induction motors, used in most manufacturing plants world wide,especially when getting over the 5 hp range. They have a 3 phase power source. Many of the smaller ones are powered by DC but between the DC source and the motor something converts it to three phase 'AC'.
It depends on the application and power source(s) available. This will break it down further.
Here is what DuckDuckGo says: "A three-phase induction motor is an electric motor that operates using three-phase power, which creates a rotating magnetic field in the stator. This magnetic field induces a current in the rotor, causing it to turn and produce mechanical energy, making these motors efficient and widely used in industrial applications."
