Using Brushed Motor Wit Arduino
Hello guys, i'm planing on using an brushed motor instead of a brushless motor, to my project. After some search, i found that project from a guy how use a potentiomenter to control the brushed motor, but i'm in doubt how i can implemente her code with mine.
Here is my code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>
RF24 radio(3, 2);   // nRF24L01 (CE, CSN)
const byte address[6] = "00001";
unsigned long lastReceiveTime = 0;
unsigned long currentTime = 0;
Servo esc;  // create servo object to control the ESC
Servo servo1;
Servo servo2;
int escValue, servo1Value, servo2Value;
// Max size of this struct is 32 bytes - NRF24L01 buffer limit
struct Data_Package {
  byte j1PotX;
  byte j1PotY;
  byte j1Button;
  byte j2PotX;
  byte j2PotY;
  byte j2Button;
  byte pot1;
  byte pot2;
  byte tSwitch1;
  byte tSwitch2;
  byte button1;
  byte button2;
  byte button3;
  byte button4;
Data_Package data; //Create a variable with the above structure
  pinMode(relaypin1, OUTPUT);
  pinMode(relaypin2, OUTPUT);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.setPALevel(RF24_PA_LOW);
  radio.startListening(); //  Set the module as receiver
  resetData();
  esc.attach(10);   // Arduino digital pin D10 - CH9 on PCB board
  // Check whether we keep receving data, or we have a connection between the two modules
  currentTime = millis();
  if ( currentTime - lastReceiveTime > 1000 ) { // If current time is more then 1 second since we have recived the last data, that means we have lost connection
    resetData(); // If connection is lost, reset the data. It prevents unwanted behavior, for example if a drone jas a throttle up, if we lose connection it can keep flying away if we dont reset the function
  // Check whether there is data to be received
  if (radio.available()) {
    radio.read(&data, sizeof(Data_Package)); // Read the whole data and store it into the 'data' structure
    lastReceiveTime = millis(); // At this moment we have received the data
  // Controlling servos
  servo1Value = map(data.j2PotX, 0, 255, 0, 180); // Map the receiving value form 0 to 255 to 0 to 180(degrees), values used for controlling servos
  servo2Value = map(data.j2PotY, 0, 255, 0, 180);
  servo1.write(servo1Value);
  servo2.write(servo2Value);
  // Controlling brushless motor with ESC
  escValue = map(data.j1PotY, 127, 255, 1000, 2000); // Map the receiving value form 127 to 255 to  1000 to 2000, values used for controlling ESCs
  esc.writeMicroseconds(escValue); // Send the PWM control singal to the ESC
void resetData() {
  // Reset the values when there is no radio connection - Set initial default values
  data.j1PotX = 127;
  data.j1PotY = 127;
  data.j2PotX = 127;
  data.j2PotY = 127;
  data.j1Button = 1;
  data.j2Button = 1;
  data.pot1 = 1;
  data.pot2 = 1;
  data.tSwitch1 = 1;
  data.tSwitch2 = 1;
  data.button1 = 1;
  data.button2 = 1;
  data.button3 = 1;
  data.button4 = 1;
And here is the code how i get from another project
#include <Servo.h> //Arduino Servo Library
Servo ESC;  // ESC için bir obje tanımlanıyor.
float value;    // Analog pin A1 den veri okuma için değişken tanımlaması.
  ESC.attach(3);  // Pin 3 den PWM sinyal çıkışı.
   for(int i = 0; i < 50; i++)
      value=value+analogRead(A1); // Potansiyometreden gelen değeri daha kararlı veriye çevirmek için 50 kez toplanıp ortalamasının alınması.
      delay(1);
  value=value/50; // Ortalama değer
  value=map(value, 0, 1023, 0, 180); // Analog girişten okunan değerin ESC nin anlayacağı değerlere çevrilmesi.
  ESC.write(value);                    // Potansiyometreden gelen değere göre ESC / servo konumunu ayarlar.
  Serial.print("Değer= ");
  Serial.println(value);
So, i'm using the value how income from a joystick, yours has some idea how i can do that?
Why drop a brushless for a brushed motor?
You need a motor driver made for brushed motors, like a H-bridge. What hardware have You got?
So, i'm planing made a RC Car, and the ESC how i got are only unidirectional, and a Brushed motor is bi.Its the Brushed Motor How i planing in use. and here is the esc how i'm planing in get. Or u have some better idea?
Sorry. Aliexpress sales pages gives me no useful information.
Reading a pot, a joystick, is one part of the project. No problem. Operating a motor is a different matter. Also no problem.
I use a motor H bridge for DC motors.
U think an H Bridge support that motor how i sent?
I don't read Spanish so I can't tell. Likely it works.
