VS1838B IR Sensor with HW-477 Module Pins
I ordered Universal IR Receiver and I got HW-477 module with VS1838B IR Sensor.
Good thing is datasheet for VS1838B is available but not for HW-477.
VS1838B pins as: Ref
Signal | GND | VCC
while HW-477 says:
  • | R | G
Can't understand which one to follow and R is for Receiver? G is for GND and what is - (minus sign) for?
So can anyone help me with ( - R G ) of HW-477 ?
Trace the foil traces to see where they end up, or use an DMM/OHM METER.
I think R is receive.
You might find a TSOP4838 is a better choice/range; that’s what I’ve found.
Foil tracing doesn't worked here because the circuit as whole is coated.
Using "Connectivity" (Continuity (diode test)) option of Digital Multimeter, found these to play beep:
VS1838B | HW-477
Signal      =       G & (minus pin of HW-477)
GND        =       (minus pin of HW-477)
VCC          =       R
More confusion here & here
