I just don't understand the color coding of this resistor. I have mesured it to be 22ohm, and it stands 22R on the strip, but i don't understand the colors.
It's a little heard to se on the picture, but the colors are from the left red, brown, black, gold...(?) and brown.
They look, left to right, Red, Red, Black, and Gold so I see 22 no multiplier or multiplier zero followed by Gold for a 5% tolerance. So I see a 22 Ohm resistor having a tolerance of 5%.
Most modern metal film resistors (cyan body) are 1% or better, so the 3-digit + multiplier + tolerance code
(the 5-band code) is commonly used since these resistors are made in the E48, E96 or E192 values.
Older carbon-film resistors (beige body) were most commonly 10% or 5% and the 2-digit + multiplier +
tolerance (4-band) code was common then since they were usually E12 or E24 values only.
For instance I've inherited a box of yellow/white/white/gold/violet resistors, which are 49.9 ohm 0.1%
499 is an E96 value
JCA34F is correct here, these are 1%.
(BTW some older resistors with 5-bands and a gold 4th band were different, but that's not the case
here with standard modern metal-film in my experience, a 4th gold band is a 0.1x multiplier - all my
stock resistors in the range 1 to 91 ohms are the modern coding)
You and me both! I have started double checking resistors on a meter now. When I buy more, I try to get the three band types where I can. I think the new background colour adds to the difficulty with reading as well as it is not immediately obvious which end is band one.
I, for one, welcome the new 5-band resistors. I think you will soon find that they are the only kind manufactured. It's cool to have 1% resistors for basically no additional cost - and with no difficulty finding a particular value.
aarg:
Yes, but still no way to make an exact 1:10 divisor with 2 resistor values...
I have almost abandoned colour coded resistors these days, preferring a simple A4 folder of surface mount parts to a whole rack of small draws.
The solder very well between tracks on a strip board or across breakers in the track.
I only use through hole resistors for photographs of stuff I am having published.
Yes Mike, that is certainly a good idea and I have done it with bypass capacitors on linear regulators. However, getting older means a lack of dexterity and eyesight which makes SMD life interesting to say the least. That may also be why I don't like the four band resistors, I just can't see what they are at a quick glance like I can with the older ones.
