Arduino: 1.8.12 (Windows 10), Board: "ATmega1284, Yes (UART0), Standard pinout, 1284P, BOD 2.7V, LTO disabled, External 20 MHz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\desit\AppData\Local\Arduino15\packages -hardware C:\Users\desit\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\desit\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\desit\Documents\Arduino\libraries -fqbn=breadboard:avr:barkeeper -vid-pid=1A86_7523 -ide-version=10812 -build-path C:\Users\desit\AppData\Local\Temp\arduino_build_891231 -warnings=all -build-cache C:\Users\desit\AppData\Local\Temp\arduino_cache_996131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -verbose C:\Users\desit\Documents\Arduino\Sketchbook\Barbot__Ref-Bot_2\Barbot__Ref-Bot_2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\desit\AppData\Local\Arduino15\packages -hardware C:\Users\desit\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\desit\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\desit\Documents\Arduino\libraries -fqbn=breadboard:avr:barkeeper -vid-pid=1A86_7523 -ide-version=10812 -build-path C:\Users\desit\AppData\Local\Temp\arduino_build_891231 -warnings=all -build-cache C:\Users\desit\AppData\Local\Temp\arduino_cache_996131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -verbose C:\Users\desit\Documents\Arduino\Sketchbook\Barbot__Ref-Bot_2\Barbot__Ref-Bot_2.ino
Using board 'barkeeper' from platform in folder: C:\Users\desit\Documents\Arduino\hardware\breadboard\avr
Using core 'arduino' from platform in folder: C:\Users\desit\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2
Detecting libraries used...
"C:\Users\desit\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=20000000L -DARDUINO=10812 -DARDUINO_AVR_1284_BAR_KEEPER_BOT -DARDUINO_ARCH_AVR "-IC:\Users\desit\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino" "C:\Users\desit\AppData\Local\Temp\arduino_build_891231\sketch\Barbot__Ref-Bot_2.ino.cpp" -o nul
Alternatives for pins_arduino.h: []
ResolveLibrary(pins_arduino.h)
-> candidates: []
In file included from C:\Users\desit\AppData\Local\Temp\arduino_build_891231\sketch\Barbot__Ref-Bot_2.ino.cpp:1:0:
C:\Users\desit\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Arduino.h:258:10: fatal error: pins_arduino.h: No such file or directory
#include "pins_arduino.h"
compilation terminated.
exit status 1
Fehler beim Kompilieren für das Board Bar-Keeper Bot @20MHz.
Ungültige Bibliothek C:\Users\desit\Documents\Arduino\libraries__MACOSX in keine Header-Dateien (.h) in C:\Users\desit\Documents\Arduino\libraries__MACOSX gefunden gefunden
hab vor allem keine Ahnung, warum ein Ordner Namens __MACOSX auf nem Windows Rechner gesucht wird.
Kann nix mehr kompilieren für mein Board. vor 3 Stunden ging es noch.
Win 10. IDE 1.8.12
LG Stefan
