Hello guys, i'm doing a project with 412 addressable RGB Leds using arduino uno.
The problem is, all the wires are connected right, like the diagram down below but when i load the sketch, the leds doens't turn on.
i'm also using a 5v 20a power supply.
Paul_B
2
Not obvious exactly how you wired the LED strip.
Read the instructions - point 7 - to post your code.
Not sure whether 412 NeoPixels exceeds the memory capability of the fake (but just the same in regard to code) UNO.
pert
3
Is the resistor only poked through the hole in the Arduino board? Or did you solder it? Same question with the ground wire.
Paul_B
4
I didn't notice that. It isn't actually connected?
