X y pen plotter coding problem
I am making x y pen plotter . Tool which is using
-arduino uno with cable
-Cnc shield v3
-2 a4988 shield driver
-2 stepper motor
-sg90 servo motor
-12v adapter charger
Need help for install app and coding for regularly use for many projects
Hello sumitchauhan5900
Take a view here to get started.
I have deleted your other cross-post/hijack @sumitchauhan5900.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Need Arduino setup coding to build the x y pen plotter
Your topic looks like an order rather than request for help. Do you ready to pay for it? If so, I can move your thread to an appropriate category for pay work.
You make the code and the wiring, not forum. If it needs corrections forum is there for you.
The goal for forum is helping new members learn and grow in programming. It's not a free toy giveaway shop.
If you want some help, search howtomechatronics pen plotter on ytb.
he also has a website with a detailed article about the build.
You will find all the information about the software.
Credit : dejan@howtomechatronics
For this build he uses, open source GRBL software on the arduino and GRBL Plotter as control software on a pc.
It's now your job to integrate this into your own build. :slight_smile:
