Adafruit motorshield v2.3 and nrf module
So im making a project which includes 2 adafruit motorshield v2.3 each, and nrf pa/lna module all working together on the reciever side. Ideally they should be working right?
Well, when i first tested the setup, the nrf module was giving the desired output even after being connected on top of the, at that time, single stacked shield,
However, today i tried it again, and it stopped working. The nrf module is working fine whne connected directly to the arduino, however when i connect the motorshield and then the nrf module, it dosent recieve any data and gives 0 as output.
Then i tried to simply connect the motorshields using wires, they could be stacked and the stack can be connected using wires to the arduino right?
My connections were:-
Arduino. Motorshield
SDA. -> SDA
SCL. -> SCL
5v. -> 5V
Gnd. -> gnd
However as soon as i connected the SDA and SCL wires to the arduino, the nrf module just froze and stopped giving anyoutput whatsoever, and the moment i remove the pins, it starts working perfectly again.
Whats the problem here, i can provide more info if required....
Had you provided a schematic, as requested in How to get the best out of this forum, this question wouldn't be necessary: what pins are you using for the radio module's CE and CSN?
i used the general pins for the nrf module on both the transmitter and the receiver sides.
as you can see from the colour code:-
CE - dig 9
CSN - dig 10
SCK - dig13
MOSI - dig 11
MISO - dig 12
vcc - 5v (PA/LNA with the adapter requires 5v)
gnd - gnd
upon connecting the motor shield and then the nrf module, i ran a test to see if it was a receiver side issue or a transmitter side issue, and it is most definately a receiver side issue because i got this as the output:-
STATUS		= 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1	= 0x0000000000 0x0000000000
RX_ADDR_P2-5	= 0x00 0x00 0x00 0x00
TX_ADDR		= 0x0000000000
RX_PW_P0-6	= 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA		= 0x00
EN_RXADDR	= 0x00
RF_CH		= 0x00
RF_SETUP	= 0x00
CONFIG		= 0x00
DYNPD/FEATURE	= 0x00 0x00
Data Rate	= 1 MBPS
Model		= nRF24L01+
CRC Length	= Disabled
PA Power	= PA_MIN
ARC		= 0
with VIN jumper attached
Without VIN jumper attached
both times i got the same result
by the way, the code i use to check my nrf modules functionability is this:-
  If your serial output has these values same then Your nrf24l01 module is in working condition :
  EN_AA          = 0x3f
  EN_RXADDR      = 0x02
  RF_CH          = 0x4c
  RF_SETUP       = 0x03
  CONFIG         = 0x0f
  This code is under public domain
  Last updated on 21/08/28
  https://dhirajkushwaha.com/elekkrypt
#include <SPI.h>
#include <RF24.h>
#include <printf.h>
RF24 radio(9,10);
byte addresses[][6] = {"1Node", "2Node"};
  radio.begin();
  radio.setPALevel(RF24_PA_LOW);
  radio.openWritingPipe(addresses[0]);
  radio.openReadingPipe(1, addresses[1]);
  radio.startListening();
  printf_begin();
  radio.printDetails();
//  empty
and i uploaded it to my setup while the adafruit shield was connected to the arduino using wires and the nrf was connected to the arduino. And i got perfect result. the nrf module is working fine. Which means that my arduino freezes the moment i insert the SDA and SCL pins. that seems to be the real problem. any solutions??
And what 2 pins does the motor shield use for the servo PWM pins?
hmmm, That makes sense, although I plan to move the servo using the dedicated servo pins on the motorshield at the top left f the shield, however in my code I have attached it at pin 10
 flexServo.attach(10);
should i change it?
also, idk how but when tried attaching the motorshield on top of the arduino and uploaded my code the nrf module was WORKING AGAIN. how does this happen i have no clue, and this time i attached all motors and it was working perfectly.... Praise the Omnissiah.
although, should i make amends in the servo pin or is it alright?
