Anemometer suggestions without moving parts
Are there any anemometers without moving parts for Arduino that have really low resolution? (0.01 m/s)
The only ones I have found are by Renkeer and they are hard to get by where I am as they only ship from China.
Does anyone have any alternatives under the $1000 range?
How is wind speed measured without moving parts? A pressure plate?
One approach is to measure the Doppler effect of ultrasonic signals in the moving air. With two ultrasonic beams at right angles, you can also get wind direction.
Example1: Arduino Ultrasonic Anemometer Part 1: Getting started | soldernerd
Example2: https://www.instructables.com/Sonic-Anemometer/
Have you looked into hot wire anemometers?
We would need to know the highest wind speed you would expect.
link?
Only need it for a few m/s max, maybe less than 20m/s
Ultrasonic Anemometers | Wind Anemometer - Renke (renkeer.com)
I am not sure if I can connect one in a module with other sensors
So you should specify what shipping restrictions you have.
I cant get anything from China. The anemometer you linked, can I make it work with an Arduino UNO?
Not ideal but with 433Mhz rf module, like cc1101, should be doable.
It's usually paired with wifi gateway and it has Home Assistant integration.
@aamirghare
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
