Arduino Micro -- windows 10 driver?
I've just received my Micro board and plugged it in.
As far as I can see there is no entry in device manager. The guide suggests the drivers should install automatically. There don't seem to be any direct links for drivers.
On the plus side, the lights come on, so it's definitely connected.
Is it necessary for me to download the IDE? I really just want the Micro to be seen initially as an input device, eventually as a MIDI device ( I think I read somewhere there's a simple way to do this?)... from there I plan to program with Python.
Any advice? (sorry I'm a total newbie to arduino!)
So.. I DLd the IDE and the drivers seemed to install OK. IDE sees the device (still nothing in device manager)
I have MIDI_USB library installed -- I guess I'm looking for some code to upload to the device so it can be seen as a MIDI device by other programs?
On some versions of windows you may need to enable "Show Hidden Devices" in device manager.
Quite often the IDE can spot the board if it is an original Arduino as the IDE will install the required drivers.
Good idea! Unfortunately, still doesn't reveal anything.
IDE definitely sees it, but I just tried uploading the default empty sketch to the Micro, and got the following (in red):
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
No idea if that's normal?
Chinese clone or a true Arduino ?
Pics would also help (both sides of the board) as some sellers don't know the difference between a micro and a mini which are two different items.
Please take a few moments to Learn and Use the Forum.
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your project.
It will help you get the very best out of the forum in the future.
  • Mention if you are using AI generated code it is important information.
  • Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or CODE tags to add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks sterretje )
  • Add your sketch where applicable but please use CODE TAGS
  • Add a SCHEMATIC were needed even if it is hand drawn.
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can.
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO USB connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
That is normal in IDE 2.x. Upload is OK.
Sorry, should have said -- genuine Arduino Micro, says Micro on it.
It seems all is good so far then...
Just went to github and got MIDIUSB_write.ino from the examples folder -- copied and pasted the code into IDE, then uploaded to device.
Now I can see it as a MIDI device in my DAW, so that's a big step forward!
Time to attach something to it (a potentiometer is my first experiment) and see where I go from there!
