I'm trying to set up a pulse generator to generate short LVTTL/TTL pulses with an Arduino. Since I'm pretty much an electronics beginner, I need some help setting up the circuit. The Arduino pulses shall send a start trigger signal to a digital timing device that only accepts LLTTL/TTL signals at a BNC 50 ohm input.
I know that the Arduino digital pins do not supply enough current to send the start trigger signal to the 50 ohm BNC port of the timing device. I did some research and read that a MOSFET could be a way to solve that problem. Unfortunately, I am slightly lost which MOSFET to choose for this application and how to set up the circuit in general.
Can anyone give me some advice on how to pursue? Thanks a lot!
Not sure what exactly you are trying to do, if you are wanting to select a MOSFET to be switched by an Arduino (ex. UNO) look for a logic level MOSFET (can be controlled by 5v logic).
These are some of the MOSFETS that fit this category.
Does the device that requires the trigger pulse actually have a 50Ω terminating resistor at it's input?
... or does it merely use a '50Ω BNC connector' to make connections to a high resistance input?
If it is the latter, then you can simply make a direct connection.
For instance:
I know that my Function/Arbitrary Waveform Generator uses a BNC connector for its trigger input, but has a 100kΩ input impedance, and I can trigger it from an Arduino pin.
Thanks to everyone who replied to my post. The timing device is a Digital-to-Time Converter by Surface Concept (SC-TDC 1100 S-Series). The manual specifies "that all inputs are internally 50 ohm terminated and are laid out for 50 ohm terminated LVTTL signal levels".
For a LVTTL signal the high logic level should have at least 2.4 V. I assume against the 50 ohm resistor I need a line driver with around 48 mA output current, better more. I've found the SN74ACT244, but the absolute maximum continuous output current is only +/- 50 mA. I didn't find a better alternative yet. Would it be possible to use two outputs of the SN74ACT244 and switch the outputs in parallel?
