I need to create a system that logs users who scan keycards on a RC-522 RFID module. The users would be logged on the Arduino, but I then need a way to see who scanned their card, so I thought to add a bluetooth module (HC-05). I've used this bluetooth module in the past to send data from a phone to the arduino, but is the reverse also possible? Note that I don't need live updates, I just need to connect to the HC-05 via app on an Android phone and then request for the data via app and have that data be sent from the HC-05 to the phone.
Thank you.
you can write an app on your android phone to do this. MIT App Inventor makes it not to difficult to get going
Yes, data can be sent to the smartphone.
Perfect, thank you both
About any Bluetooth terminal app can be used to do this. You don't need to re-invent the wheel with App Inventor.
That was assuming you want a dedicated UI to get the list and process the returned info in some way (other than copy paste).
Yeah, I need a simple UI that people can use without trying to figure out Bluetooth terminal apps
