Hi all
I when upload code in esp32 cam, upload is success but show this message :
Leaving...
Hard resetting via RTS pin...
I saw this link but this could not help me
this message when does it happen??? and for solved this problem what to do???
Hi all
Leaving...
That means your upload is complete & the board is resettig to run it, this is normal.
missdrew:
good, but when reset button, this message does not change, and esp32 cam not connect to wifi
and what should I do for this problem
key1:
good, but when reset button, this message does not change, and esp32 cam not connect to wifiand what should I do for this problem
The message output from the compiler, 'Hard resetting via RTS pin...' will not change when the ESP32CAM is reset, i.e. when you have pressed the reset button.
Take a look instead at the messages that appear in the Serial Monitor when you press the reset button on the ESP32CAM.
Hello to all
Can anyone tell me whether how to click pictures without using reset button of esp32 camera module?
have seen many tutorials and videos, info but it could not help me out.
