Hi all, I am at a complete loss, My extruders on my latest five colour mixing printer will not turn, I am using a Mega 256 with Ramps 1.4 and three add on extruders together with Marlin firmware.
At power on all extruders are free turning, no power as are X Y and Z When I ask it to home all axes X Y and Z home perfectly then I heat the hot end to 200 degrees (PLA) minimum temp set to 105 degrees, and then try to extrude on any one of the five axes and all that happens is that extruder locks solid and will not move to extrude.
I have tried changing an extruder motor and cable onto the X Y or Z pins and the extruder motors all work fine as one would expect, I have swapped the extruder A4988 drivers onto X Y axes and relevant axis work fine, have checked all voltages on the A4988s and Vcc is 5V and Vmot is 12volt the trim pots are adjusted to1.2 Volts all the same as X Y and Z The add on drivers voltages are correct as well I have set pins.h commenting out the default servo pins and I set them as follows
Very typical of plastic injection equipment! How are you sensing and controlling the heat? Are you keeping the temperature stable after the initial heat time?
AN additional thought: How do you clean the nozzles after use? I used low temp polyethelene on my injection molding machine way beck then.
Hi thanks for the quick reply, I have checked the resistance across the thermister and compared it to a new one both were very close at 1.3k and 1.4k at the ambient temperature and when working the temperature scale is rising and falling
Hi thanks for your input the extruders are geared type and nothing is binding until an instruction to move is sent then the motor seams to receive some power to lock it.
Verify all cables to motors are seated. If your cables are long enough, cross-connect (x axis to y axis) the cables to see if the problem follows the cable or follows the motor.
