Help with testing an ESP8266 binary
Hi!
I have compiled a binary for nodeMCU, but I need someone who has an alexa to test it. Its suppose to be a smart light bulb so alexa should discover it, switch it off and on.
Steps:
Flash binary using https://esp.huhn.me/
On your mobile connect to NodeMCU-Setup wifi
Setup WiFi credentials for your home wifi
Discover the device with alexa and see if it can switch it on/off.
Pin that changes is D2 so there might not be anything on it.
Link for download:
I know its an unexpected request, but if you help thanks!
I moved your topic to an appropriate forum category @ArakelTheDragon.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Not many will follow a link. Why not just post the sketch?
Because it took so much work to develop it that I don't want to share it.
Good luck
Why not get an Alexa?
Hmmm
If you can't share the sketch, what guarantees that there isn't something inappropriate in the Bin?
I wouldn't do a test without knowing what I would be loading.
Very dangerous. :skull_and_crossbones:
There is nothing dangerous about it. Binaries on the web are used all the time for various things including WiFi repeaters with the ESP8266 and the sketch is always missing.
It becomes too much of a hassle to get an Alexa and TV. Its a simple smart plug that I need testing, so far I think the project will work, but there is no way to be sure without testing.
Exactly what a spambot would say.
You are right. That is why the virus scanner business if flourishing.
But you expect others who have it to just do your bidding?
I don't agree. I can not share the sketch, but if there is anything I can do for someone to just check if the device is discoverable and does alexa switch it on/off it would be great.
Yes you can. Viruses are shared all the time under the guise of something else, like an Alexa widget.
Try...
If I weren't so lazy, I would buy a stand-alone Alexa system and pass the cost on to you, just for one test... pass or fail.
