I'm fairly new to Arduino and was hoping for some advice about using a 6V micro 3-way solenoid by controlling it somehow with a Uno.
The specs are:
【Rated Voltage】 DC 6V
【Current】 220mA
【Suitable Voltage】 DC 5V-6V
【Power】 < 2W
【Pressure Range】 0-46.66KPa (0-350mmHg)
【Use Medium】 Gas
【Wire Length】 15CM
【Weight】 about 16g
Wiring Instructions:
When power off, 1 and 3 pass, 2 is blocked;
When power on, 1 and 2 pass, 3 is blocked.
I currently have some 2N2222 NPN Switching Transistors but that's about as far as I've got. I've done some reading and am cautious to try anything out in case I might damage something. I understand that, if using transistors, I will need to use diodes as well, however I'm not sure which the right ones would be.
I also read that an octocoupler might also be an option, however, again, I'm not sure which I would need. As I understand it, both octocouplers and transistors are designed to increase power (?), however, all I need is to switch the power to the valves on or off.
If someone could point me in the right direction, that would be very much appreciated.
