Hi, I am using two HW-201 IR sensors for a simple object-following robot. I want the robot to detect my hand, but the sensors only detect 1 cm away. It detects a little better if I use white paper instead of my hand, but it is still only around 2-3 cm. Is that normal for these types of sensors? Is there a way to increase the detection range? Thank you.
Nevermind, I just found out I can adjust the potentiometer with a screw. Sorry, I'm a noob here
You should provide a link to any components you mention on a thread, to save others having to track it down and perhaps find the wrong one.
But the links I found show that there's an adjustment pot on those sensors. What happens when you change it?
edit... Ok you found it yourself. I'll leave the pic here for others.
Good to know, thank you! I'll include a link next time
