Long Range Trasmission
Hello Community,
I'm very bit confusing on what is the best solution for have a long range communication.
At first instant the main requirement is to achieve a 1Km, outdoor with possible little bit obstacle like tree or like of that,communication between a transmitter and receiver connected to the respective arduino Mega with baud rate useful for send/receive command/message.
I've seen some product concerning a datasheet:
Could you help me with some advice on what product to buy and the better antenna used?
Mafer
Natures warning sign, if this were cheap/easy, you would already see a lot of people implementing it.
What are you trying to transmit?
Those kits are for transmitting 4 bit nibbles at a very low data rate.
They are usually for remote control applications.
As for the range , like most cases its totally dependant on whats in the way between the transmitter and receiver.
Hello Mauried,
I'm trying to transmit a servo command but also some data coming from sensor and/or for GPS data.
I would like to have a bidirectional communication.
At the end I would like to understand if I can achieve a video streaming for 1km and fix the right product and/or solution could be.
Maybe I would like to highlight a possible solution and comparing the costs for a good planning.
In the meantime I would like to trace what improvements I must put in place and if is possible addressed a choice on the right way since at beginning.
//Mafer
Those 433 Mhz modules are uni directional and not suitable at all for video streaming due to their low data rate.
Look at an Xbee or NRF24l01, as both as bi directional, but video streaming is still a tuff ask.
Many thanks,
but regarding xbee and/or Extend coming from Digi, which is the range that I can achieve based on the experience?
//Mafer
If one end is a computer then a HM-TRP pair (one having a USB interface) is the way to go. These are frequently used for UAV "telemetry" so you'll have no problem finding comments on their range if you do a little searching.
Personally I think XBees are a bad route to take: They're expensive, the Zigbee protocols are overly complex, and they're already outdated with the eruption in cheaper WiFi solutions.
Hello Chagrin,
thanks for your feedback.
No any PC is foreseen in my project, could you advice to me a possible device from this supplier?
Do you think device/module that you have mentioned are compliant to my requirements?
thanks again
//Mafer
