I installed the Create Agent on my MAC os Catalina 10.15.7.
But I see neither the icon on the top bar nor is it operational when I enter the Cloud and when I go to the Web Editor it tells me that the Create Agent is not active.
I have tried to install it again and to annex .the application but nothing changes.
EzioGi
Hi @eziogi. Hi @rohinideshmukh. This problem may be caused by certain security restrictions of your web browser blocking the communication between Arduino Cloud and Arduino Create Agent.
I'll provide instructions you can follow to configure Arduino Create Agent for use with all web browsers:
- If it is not already running, start Arduino Create Agent.
ⓘ If you see an Arduino Create Agent icon on the macOS menu bar then it is running. - Control-click on the Arduino Create Agent icon on the macOS "menu bar".
A menu will open. - Select Generate and Install HTTPS certificates from the menu.
A "You are making changes to your Certificate Trust Settings" dialog will open. - Enter your macOS user password in the "You are making changes to your Certificate Trust Settings" dialog.
- Click the "Update Settings" button.
After doing that, you should find that Arduino Cloud is able recognize that Arduino Create Agent is running and recognizes the Arduino boards you have connected to your computer.
Please let me know if you have any questions or problems while following those instructions.
Thank you for your help.
Problem solved
EzioGi
You are welcome. I'm glad it is working now.
Regards,
Per
Problem solved by reinstalling and starting "Arduino Create Agent "but today I noticed that it no longer allows me to see the "Generate and install HTTPS certificates" menu, I can't make the change you recommended, that of entering the macOS User Password.
The Cloud is working normally.
Regars
EzioGi
HI,
this is what I see:
EzioGI
