Missing Drivers, Can't Connect To Computer?
Hey! I'm brand new to Arduino, just got the starer kit for christmas and I'm pumped about it.
However, I've followed every tutorial online and nothing seems to be working. I go to the device manager to update the drivers, connect the path to the arduino driver folder and it comes up saying windows can't find any drivers.
I've restarted my computer, updated it, tried every USB port, redownloaded Arduino, deleted the device and tried again, tried downloading the drivers from else where with no success.
I'm at loss right now and just hoping I missed an obvious step.
-Snorkelhead
If your Arduino is a clone then you may need the drivers from http://www.wch.cn/download/CH341SER_ZIP.html
It's in Chenese buy if you click on the blue square in the CH341SER.ZIP box then it'll download.
This worked for mine on a Win10 64 bit PC.
Peter
Peterd51:
If your Arduino is a clone then you may need the drivers from CH341SER.ZIP - 南京沁恒微电子股份有限公司
Peter
I tried this link early and still nothing sadly, Im also pretty sure mine isnt a clone or knock off arduino anyways
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Posting tips.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
Bob.
