4N35
You have not wired the Opto properly.
Don’t use pin 6
Use pins 5 (collector) and 4 (emitter).
You can experiment with connecting pin 6 to GND through a base resistor.
Start with a 100k, this should/might square the waveform a bit better than we see now.
Looks pretty good to you correct?
You can experiment with connecting 4N35 pin 6 to GND through a base resistor.
Nice, looks good.
There are tons of alternatives, e.g. the PC817 (also comes in multi packs, like the PC847 with four optos in one IC).
Given a choice I'd always go with current parts, not discontinued parts. They're discontinued for a reason, usually because they're obsolete: better & cheaper alternatives have become available.
Hello all! new to the site. Very interested in building one of these for my vehicle. My ECU is fried and I would like to build this Transmission controller. This post is directed to darmfield12. It would be much appreciated if you could contact me directly.
Thanks, Sean
