No Label option for Dashboard
How is it possible that there is no option to add a basic label to a dashboard? Good grief!
Hi @ScottMurchison. Thanks for your feedback.
I'm not sure I understand what you mean by "basic label". Please provide a detailed description of the feature you are missing in a reply here on this forum topic. That will ensure we are clear about the exact nature of your request.
Thanks for getting back to me. I created a dashboard project to monitor 12V batteries in two trailers. I use them for auxiliary lighting. At the top, I want a label, ot title, that says “Trailer Battery Voltage Monitor”. I did it by making it a jpg image and adding it, but I think that there should be a widget to add a text string that doesn’t need to be tied to a variable (thing).
Excellent solution!
As an alternative, you could use the "Sticky Note" widget:
However, I think your solution is actually superior as it gives you unlimited control over the styling of the title.
I can’t edit the text in the sticky notes widget.
I also encountered this confusion. It has an unintuitive design where you can only edit the content of the Sticky Note widget after changing the Dashboard out of the "Edit" mode:
  1. Open your Dashboard.
  2. Click the "EDIT" button.
  3. Click the "ADD" button.
  4. Select "Sticky Note" from the list of Widgets.
    The "Widget Settings" dialog will open.
  5. Configure the appearance of the widget according to your preferences.
  6. Click the "DONE" button in the "Widget Settings" dialog.
    The dialog will close and the Sticky Note widget will be added to your dashboard.
  7. Adjust the size and position of the Sticky Note widget according to your preferences.
  8. Click the "DONE" button.
  9. Click on the Sticky Note widget.
  10. Edit the text as needed.
Ok, that worked, but wow, that was not intuitive and I started testing software back in the 1980s.
I have submitted a request to the Arduino Cloud developers to allow editing the content of the "Sticky Note" widget during setup, and while editing the dashboard.
Thanks, but please also suggest that they add simple static labels also.
