RFID sensor doesn't communicate with Arduino
I'm heaving an issue getting my RFID-RC522 to work on the Arduino ONU and NANO, already struggling 4 days with this problem and I can't find anything about it. I've tried 6 different RC522's and 3 different Arduino's
The problem is as following: I try to connect the Arduino to the RC522 and this seems to work, when I open the Example library of the MFRC522 → Dump info and I connect everything like the description tells me to do. I get this:
When I connect the Arduino to the RC522 and open the Serial Monitor, I get the message:
"Firmware Version: 0x92 = v2.0"
When I unplug the RC522 and run the serial monitor, I get the message:
"Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?"
So this means the connection between the Arduino and the RC522 works, but still, with 6 different RC522's, I get absolutely nothing out of it.
I found something about the BUS protocol not connecting properly between the Arduino and the RC522, but is can't find what I should do about it.
Almost everyone on the web seems to get it working the way it's described in the library, but I have tried everything and the RC522 just doesn't read anything.
Hard to say without more information...
Post the code you are using.
Post a clear pic of how everything is connected.
RFID sensor (RC522) is connected like shown in the code
 * Example sketch/program showing how to read data from a PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * Example sketch/program showing how to read data from a PICC (that is: a RFID Tag or Card) using a MFRC522 based RFID
 * Reader on the Arduino SPI interface.
 * When the Arduino and the MFRC522 module are connected (see the pin layout below), load this sketch into Arduino IDE
 * then verify/compile and upload it. To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M). When
 * you present a PICC (that is: a RFID Tag or Card) at reading distance of the MFRC522 Reader/PCD, the serial output
 * will show the ID/UID, type and any data blocks it can read. Note: you may see "Timeout in communication" messages
 * when removing the PICC from reading distance too early.
 * If your reader supports it, this sketch/program will read all the PICCs presented (that is: multiple tag reading).
 * So if you stack two or more PICCs on top of each other and present them to the reader, it will first output all
 * details of the first and then the next PICC. Note that this may take some time as all data blocks are dumped, so
 * keep the PICCs at reading distance until complete.
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * More pin layouts for other boards can be found here: https://github.com/miguelbalboa/rfid#pin-layout
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	delay(4);				// Optional delay. Some board do need more time after init to be ready, see Readme
	mfrc522.PCD_DumpVersionToSerial();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
	// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
How is it powered, and do you have a common GND ?
It's powered on 3V3 like it should be, and the GND is indeed common connected with the Arduino.
For your reference, it's connected like shown below.
Problem Solved!
All the code shown in the library and on the web does not work for me, I found a simple YouTube video posted 2 months ago. In this video the RC522 is connected exactly the same way I have tried a dozen times, but he made an Arduino code himself I guess?? The code he shows in the description worked instantly for me, tried it with both my Arduino UNO's, my NANO and all the RC522's I have. Everything works every time!
I am very happy I found this video, but can someone tell me what the difference is between the code I send earlier in this Topic and the code below??
Link to the YouTube video: How to make Arduino RFID Door lock System | DIY MFRC522 - YouTube
#include <SPI.h>
#include <Wire.h>
#define RST_PIN 9
#define SS_PIN  10
#define STATE_STARTUP       0
#define STATE_STARTING      1
#define STATE_WAITING       2
#define STATE_SCAN_INVALID  3
#define STATE_SCAN_VALID    4
#define STATE_SCAN_MASTER   5
#define STATE_ADDED_CARD    6
#define STATE_REMOVED_CARD  7
#define REDPIN 7
#define GREENPIN 6
#define Relay 5
const int cardArrSize = 10;
const int cardSize    = 4;
byte cardArr[cardArrSize][cardSize];
byte masterCard[cardSize] = {356,64,93,418};   //Change Master Card ID
byte readCard[cardSize];
byte cardsStored = 0;
// Set the LCD I2C address
byte currentState = STATE_STARTUP;
unsigned long LastStateChangeTime;
unsigned long StateWaitTime;
int readCardState()
  int index;
  Serial.print("Card Data - ");
  for(index = 0; index < 4; index++)
    readCard[index] = mfrc522.uid.uidByte[index];
    Serial.print(readCard[index]);
    if (index < 3)
      Serial.print(",");
  Serial.println(" ");
  //Check Master Card
  if ((memcmp(readCard, masterCard, 4)) == 0)
    return STATE_SCAN_MASTER;
  if (cardsStored == 0)
    return STATE_SCAN_INVALID;
  for(index = 0; index < cardsStored; index++)
    if ((memcmp(readCard, cardArr[index], 4)) == 0)
      return STATE_SCAN_VALID;
void addReadCard()
  int cardIndex;
  int index;
  if (cardsStored <= 20)
    cardsStored++;
    cardIndex = cardsStored;
    cardIndex--;
    cardArr[cardIndex][index] = readCard[index];
void removeReadCard()
  int cardIndex;
  int index;
  boolean found = false;
  for(cardIndex = 0; cardIndex < cardsStored; cardIndex++)
    if (found == true)
        cardArr[cardIndex-1][index] = cardArr[cardIndex][index];
        cardArr[cardIndex][index] = 0;
    if ((memcmp(readCard, cardArr[cardIndex], 4)) == 0)
      found = true;
  if (found == true)
    cardsStored--;
void updateState(byte aState)
  if (aState == currentState)
    return;
  // do state change
  switch (aState)
    case STATE_STARTING:
      StateWaitTime = 1000;
      digitalWrite(REDPIN, HIGH);
      digitalWrite(GREENPIN, LOW);
    case STATE_WAITING:
      StateWaitTime = 0;
      digitalWrite(REDPIN, LOW);
    case STATE_SCAN_INVALID:
      if (currentState == STATE_SCAN_MASTER)
        addReadCard();
        aState = STATE_ADDED_CARD;
        StateWaitTime = 2000;
        digitalWrite(GREENPIN, HIGH);
      else if (currentState == STATE_REMOVED_CARD)
        return;
    case STATE_SCAN_VALID:
        removeReadCard();
        aState = STATE_REMOVED_CARD;
      else if (currentState == STATE_ADDED_CARD)
        return;
        digitalWrite(Relay,LOW);
        delay(3000);
        digitalWrite(Relay,HIGH);
    case STATE_SCAN_MASTER:
      StateWaitTime = 3000;
  currentState = aState;
  LastStateChangeTime = millis();
  SPI.begin();         // Init SPI Bus
  updateState(STATE_STARTING);
  pinMode(REDPIN, OUTPUT);
  pinMode(GREENPIN, OUTPUT);
  pinMode(Relay, OUTPUT);
  byte cardState;
  if ((currentState != STATE_WAITING) &&
      (StateWaitTime > 0) &&
      (LastStateChangeTime + StateWaitTime < millis()))
    updateState(STATE_WAITING);
  // Look for new cards
    return;
    return;
  cardState = readCardState();
  updateState(cardState);
