It seems that a high frequency is used, and without further modulation. I think the base frequency could be 80kHz.
Did you use a scanning sketch for those numbers ? Are those microseconds ?
Can you give a link to the scanning sketch that you used ?
And tell us if you used a receiver module or just a bare diode for those numbers.
If those numbers are microseconds, then I can't match those number with the picture. I think something is wrong with reading the pulses in the Arduino.
That is your problem. That chip demodulates the signal so the numbers you are seeing is the length of time each burst of IR is giving you. It is way higher than the IR signal you have therefore it is giving you the best numbers it can, which in a nonsense given the high modulation frequency.
Note there is no such thing as a TSOP312(33-56), you can have a TSOP31256 or a TSOP31240 or a TSOP31238 and so on. So what one are you using?
Well one answer that you did get, was the the carrier frequency seems to be 80kHz.
If I were you I'd investigate the manufacturers of the RC timing equipment and see what the frequency is. There's no reason why their transponder should work with a receiver from another manufacturer: just becasue 38kHz is common in the world of TV remotes, it's very possible that in the RC world they settled on a diffeent frequency.
s it possible to use 40khz receviers because 80khz is multiple?
No.
If you look at the data sheet you will see there is a band pass filter in it. Also look at Figure 5. Frequency Dependence of Responsivity, and you will see it drops off very sharply.
B: Try using the sketch/setup in this post. It should be able to capture the signal, if you follow the instructions carefully. However, it was only tested up to 56kHz. Poor maker’s Infrared receiver
If it turns out to be 80kHz, it should still be possible to send it using arduino & IRremote/IRLib using the sendRAW function - provided you manage to capture the signal, of course.
Kudos on the Silver Bullet there, AnalyisIR. I just breadboarded that. At the 500us as you suggested, easy to see the spaces and marks as in your photo. Then separated the peaks in the block at 25us and easy to measure the carrier frequency.
My supplier has BNCs with rubber boots: I'll see if I can get the LED and resistor inside there.
Thank you very much for those hints....I'll try them as soon as i have all components ready.
BTW: i only got ld 274-3 here as diode....are these ok as well?
