Stepper Motor Wiring help needed
I've been trying to get my Stepper motor to work for a very long time now and I'm just stuck at this point. The motor keeps vibrating back and forth and not turning correctly. The code I am using is just a simple example code from a tutorial video. The Motor I am using is a Two trees Nema 17 if that matters, with a 12 Volt plugin from the wall. I believe it may be the wiring but I am not sure`// Define pin connections & motor's steps per revolution. Here's my wiring and code (Ignore the buttons).
const int dirPin = 4;
const int stepPin = 3;
const int stepsPerRevolution = 200;
int stepDelay=400;
  // Declare pins as Outputs
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  //clockwise
  digitalWrite(dirPin, HIGH);
  // Spin motor
  for(int x = 0; x < stepsPerRevolution; x++)
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(stepDelay);
    digitalWrite(stepPin, LOW);
  delay(2000); // Wait 2 seconds
  //counterclockwise
  digitalWrite(dirPin, LOW);
  // Spin motor
Hi Newbie welcome to the community
Kindly go through it
Guidelines
Also kindly post proper circuit diagram as the images are not sufficient to understannd
Cant tell from the pics:
i would say change the wires around to test ive had the same and switched wire positions and it started working normally.. on a way smaller stepper tho but it should work the same
With step delay of 400 microseconds that's 1250 steps per second (375 RPM). Your motor cannot jump from 0 to 1250 SPS instantly, increase step delay to 3000 (3 thousand, 50 RPM) and work your way up by making step delay gradually lower.
int stepDelay=3000;
EDIT: Please excuse my math blunder, should be correct now. :grimacing:
Thank you it is now working correctly
