Hey,
so I created a door watcher. The DS3231 turns it on every 12 hours to send status update( in code at the moment every 30 min for testing) or when the door opens.
But I have the problem that the "fona.enableGPRS(true)" randomly fails and I absolutely don't know why. I don't think it has something to do with the schematics because it happens also with the feather fona standalone.
I added some delays, because I find out, that this helps, but is there maybe another way to say: Wait for the fona to be ready?
What can I do better?
Thanks in advance.
P.S. thanks for the help in this topic:. Low Active 2A Switch , helped me a lot to create this schematic.
P.S.S. Posted this also in the adafruit forum, but in my experience, the community here is much better ![]()
#include "Adafruit_FONA.h"
#include <ArduinoJson.h>
#include "RTClib.h"
#define FONA_RX 9
#define FONA_TX 8
#define FONA_RST 4
#define FONA_RI 7
// this is a large buffer for replies
char replybuffer[255];
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
RTC_DS3231 rtc;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
char url[80] = "http://foobar.com"; //REMOVED
StaticJsonDocument<200> doc;
int dsPowerPin = 10;
int door = 0;
void (*resetFunc)(void) = 0;
void shutdown()
Serial.println("SHUTDOWN!");
rtc.clearAlarm(1);
rtc.clearAlarm(2);
void tryAgain()
Serial.print("No Succed: ");
int minutes = rtc.now().minute();
if ((minutes > 5 && minutes < 29) || (minutes > 35))
Serial.println("shutdown");
shutdown();
Serial.println("restart");
resetFunc();
void setupGSM()
Serial.println(F("Initializing....(May take 3 seconds)"));
fonaSerial->begin(4800);
if (!fona.begin(*fonaSerial))
Serial.println(F("Couldn't find FONA"));
shutdown();
while (1)
Serial.println(F("FONA is OK"));
digitalWrite(13, LOW);
delay(5000);
fona.setGPRSNetworkSettings(F("internet.eplus.de"), F("blau"), F("blau"));
delay(10000);
digitalWrite(13, HIGH);
// turn GPRS on
if (!fona.enableGPRS(true))
Serial.println(F("Failed to turn on"));
Serial.println(F("RESET!"));
tryAgain();
void setupRTC()
if (!rtc.begin())
Serial.println("Couldn't find RTC");
Serial.flush();
return;
rtc.writeSqwPinMode(DS3231_OFF);
Serial.println("RTC READY");
if (rtc.lostPower())
Serial.println("RTC lost power, let's set the time!");
//GET GSM TIME
if (!fona.enableNTPTimeSync(true, F("pool.ntp.org")))
Serial.println(F("Failed to enable"));
delay(3000);
char buffer[23];
fona.getTime(buffer, 23); // make sure replybuffer is at least 23 bytes!
Serial.print(F("Time from GSM= "));
Serial.println(buffer);
String date = buffer;
DateTime dateTime = DateTime(date.substring(1, 3).toInt(), date.substring(4, 6).toInt(), date.substring(7, 9).toInt(), date.substring(10, 12).toInt() + 2, date.substring(13, 15).toInt(), date.substring(16, 18).toInt());
rtc.adjust(dateTime);
Serial.print(F("Time from RTC= "));
Serial.println(rtc.now().timestamp());
if (!rtc.setAlarm1(
DateTime(0, 0, 0, 0, 0, 0),
DS3231_A1_Minute))
Serial.println("Error, alarm1 wasn't set!");
Serial.println("New Alarm1 set");
if (!rtc.setAlarm2(
DateTime(0, 0, 0, 0, 30, 0),
DS3231_A2_Minute))
Serial.println("Error, alarm2 wasn't set!");
Serial.println("New Alarm2 set");
pinMode(dsPowerPin, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(dsPowerPin, HIGH);
delay(3000);
setupGSM();
setupRTC();
Serial.println(F("Setup finished"));
void post()
delay(10000);
//get battery
uint16_t vbat;
uint16_t per;
fona.getBattVoltage(&vbat);
fona.getBattPercent(&per);
if (rtc.alarmFired(1) || rtc.alarmFired(2))
door = 0;
door = 1;
// Create Json
char temp[200];
doc["door"] = door;
doc["volt"] = vbat;
doc["per"] = per;
serializeJson(doc, temp);
Serial.print("JSON: ");
Serial.println(temp);
// Post data to website
uint16_t statuscode;
int16_t length;
Serial.println(F("****"));
if (!fona.HTTP_POST_start(url, F("application/json"), (uint8_t *)temp, strlen(temp), &statuscode, (uint16_t *)&length))
Serial.println("Failed!");
Serial.print("Statuscode: ");
Serial.println(statuscode);
tryAgain();
return;
while (length > 0)
while (fona.available())
char c = fona.read();
Serial.write(c);
length--;
if (!length)
Serial.println(F("\n****"));
fona.HTTP_POST_end();
Serial.println(F("send DONE"));
if (!fona.enableGPRS(false))
Serial.println(F("Failed to turn GSM off"));
Serial.println(F("GSM turned off"));
char date[10] = "hh:mm:ss";
while (Serial.available())
Serial.read();
post();
while (1)
shutdown();
delay(900000);
Serial.println("RESTART!!!");
resetFunc();
