Merci @al1fch!Par contre...
sudo dmesg
[sudo] Mot de passe de christelaurent :
[ 0.000000] Linux version 4.15.0-206-generic (buildd@lcy02-amd64-070) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #217-Ubuntu SMP Fri Feb 3 19:10:13 UTC 2023 (Ubuntu 4.15.0-206.217-generic 4.15.18)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-206-generic root=/dev/mapper/mint--vg-root ro quiet splash vt.handoff=1
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ad12bfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ad12c000-0x00000000ad15bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ad15c000-0x00000000ad16bfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ad16c000-0x00000000ad7edfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ad7ee000-0x00000000ae3e7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ae3e8000-0x00000000ae3e8fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ae3e9000-0x00000000ae5eefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ae5ef000-0x00000000aea32fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000aea33000-0x00000000aeff3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000aeff4000-0x00000000aeffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] e820: update [mem 0x8a3b8018-0x8a3c7257] usable ==> usable
[ 0.000000] e820: update [mem 0x8a3aa018-0x8a3b7857] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000008a3aa017] usable
[ 0.000000] reserve setup_data: [mem 0x000000008a3aa018-0x000000008a3b7857] usable
[ 0.000000] reserve setup_data: [mem 0x000000008a3b7858-0x000000008a3b8017] usable
[ 0.000000] reserve setup_data: [mem 0x000000008a3b8018-0x000000008a3c7257] usable
[ 0.000000] reserve setup_data: [mem 0x000000008a3c7258-0x00000000ad12bfff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000ad12c000-0x00000000ad15bfff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ad15c000-0x00000000ad16bfff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x00000000ad16c000-0x00000000ad7edfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000ad7ee000-0x00000000ae3e7fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ae3e8000-0x00000000ae3e8fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000ae3e9000-0x00000000ae5eefff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000ae5ef000-0x00000000aea32fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000aea33000-0x00000000aeff3fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000aeff4000-0x00000000aeffffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000feb80000-0x00000000fec00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000041effffff] usable
[ 0.000000] efi: EFI v32.31 by American Megatrends
[ 0.000000] efi: ACPI=0xad163000 ACPI 2.0=0xad163000 SMBIOS=0xf04c0 MPS=0xfd4c0 MOKvar=0xa1a94000
[ 0.000000] secureboot: Secure boot enabled
[ 0.000000] Kernel is locked down from EFI secure boot; see man kernel_lockdown.7
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: System manufacturer System Product Name/A68HM-PLUS, BIOS 1101 06/05/2015
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFE0000000 write-back
[ 0.000000] 2 base 0000A0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 000000041f000000 aka 16880M
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: update [mem 0xb0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xaf000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd840-0x000fd84f]
[ 0.000000] e820: update [mem 0xa1a94000-0xa1a94fff] usable ==> reserved
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] RAMDISK: [mem 0x8a3c8000-0x8e2d2fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000AD163000 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000AD163080 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000AD16A288 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20170831/tbfadt-658)
[ 0.000000] ACPI: DSDT 0x00000000AD163188 007100 (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS 0x00000000AD7E3080 000040
[ 0.000000] ACPI: APIC 0x00000000AD16A398 000072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000AD16A410 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 0x00000000AD16A458 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: HPET 0x00000000AD16A498 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: CRAT 0x00000000AD16B600 000578 (v01 AMD BANTRY 00000001 AMD 00000001)
[ 0.000000] ACPI: UEFI 0x00000000AD16A528 000042 (v01 ALASKA A M I 01072009 00000000)
[ 0.000000] ACPI: BGRT 0x00000000AD16A570 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000AD16A5A8 000B9C (v01 AMD BANTRY 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x00000000AD16B148 0004B7 (v02 AMD BANTRY 00000001 MSFT 04000000)
[ 0.000000] ACPI: Reserving FACP table memory at [mem 0xad16a288-0xad16a393]
[ 0.000000] ACPI: Reserving DSDT table memory at [mem 0xad163188-0xad16a287]
[ 0.000000] ACPI: Reserving FACS table memory at [mem 0xad7e3080-0xad7e30bf]
[ 0.000000] ACPI: Reserving APIC table memory at [mem 0xad16a398-0xad16a409]
[ 0.000000] ACPI: Reserving FPDT table memory at [mem 0xad16a410-0xad16a453]
[ 0.000000] ACPI: Reserving MCFG table memory at [mem 0xad16a458-0xad16a493]
[ 0.000000] ACPI: Reserving HPET table memory at [mem 0xad16a498-0xad16a4cf]
[ 0.000000] ACPI: Reserving CRAT table memory at [mem 0xad16b600-0xad16bb77]
[ 0.000000] ACPI: Reserving UEFI table memory at [mem 0xad16a528-0xad16a569]
[ 0.000000] ACPI: Reserving BGRT table memory at [mem 0xad16a570-0xad16a5a7]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xad16a5a8-0xad16b143]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xad16b148-0xad16b5fe]
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x41efd5000-0x41effffff]
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000ad12bfff]
[ 0.000000] node 0: [mem 0x00000000ae3e8000-0x00000000ae3e8fff]
[ 0.000000] node 0: [mem 0x00000000ae5ef000-0x00000000aea32fff]
[ 0.000000] node 0: [mem 0x00000000aeff4000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Reserved but unavailable: 115 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[ 0.000000] On node 0 totalpages: 3982620
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 26 pages reserved
[ 0.000000] DMA zone: 3999 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 11030 pages used for memmap
[ 0.000000] DMA32 zone: 705917 pages, LIFO batch:31
[ 0.000000] Normal zone: 51136 pages used for memmap
[ 0.000000] Normal zone: 3272704 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 0, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.000000] efi_bgrt: Ignoring BGRT: invalid image address
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x8a3aa000-0x8a3aafff]
[ 0.000000] PM: Registered nosave memory: [mem 0x8a3b7000-0x8a3b7fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x8a3b8000-0x8a3b8fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x8a3c7000-0x8a3c7fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xa1a94000-0xa1a94fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xad12c000-0xad15bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xad15c000-0xad16bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xad16c000-0xad7edfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xad7ee000-0xae3e7fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xae3e9000-0xae5eefff]
[ 0.000000] PM: Registered nosave memory: [mem 0xaea33000-0xaeff3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xaf000000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfeb7ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb80000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed90000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xaf000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] percpu: Embedded 50 pages/cpu s167936 r8192 d28672 u524288
[ 0.000000] pcpu-alloc: s167936 r8192 d28672 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 3920364
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-206-generic root=/dev/mapper/mint--vg-root ro quiet splash vt.handoff=1
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 15300152K/15930480K available (12300K kernel code, 2477K rwdata, 4324K rodata, 2480K init, 2720K bss, 630328K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 39485 entries in 155 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
[ 0.000000] vt handoff: transparent VT on vt#1
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] ACPI: Core revision 20170831
[ 0.000000] ACPI: 3 ACPI AML tables successfully acquired and loaded
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.020000] tsc: Fast TSC calibration using PIT
[ 0.024000] tsc: Detected 3890.567 MHz processor
[ 0.024000] Calibrating delay loop (skipped), value calculated using timer frequency.. 7781.13 BogoMIPS (lpj=15562268)
[ 0.024000] pid_max: default: 32768 minimum: 301
[ 0.024000] Security Framework initialized
[ 0.024000] Yama: becoming mindful.
[ 0.024000] AppArmor: AppArmor initialized
[ 0.030921] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.032569] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.032644] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.032700] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.032926] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[ 0.032928] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[ 0.032929] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.032931] Spectre V2 : Mitigation: Retpolines
[ 0.032931] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.032931] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.032932] RETBleed: Vulnerable
[ 0.032933] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.040146] Freeing SMP alternatives memory: 36K
[ 0.157314] smpboot: CPU0: AMD A8-6600K APU with Radeon(tm) HD Graphics (family: 0x15, model: 0x13, stepping: 0x1)
[ 0.157410] Performance Events: Fam15h core perfctr, AMD PMU driver.
[ 0.157414] ... version: 0
[ 0.157415] ... bit width: 48
[ 0.157415] ... generic registers: 6
[ 0.157416] ... value mask: 0000ffffffffffff
[ 0.157416] ... max period: 00007fffffffffff
[ 0.157417] ... fixed-purpose events: 0
[ 0.157417] ... event mask: 000000000000003f
[ 0.157456] Hierarchical SRCU implementation.
[ 0.158065] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.158077] smp: Bringing up secondary CPUs ...
[ 0.158200] x86: Booting SMP configuration:
[ 0.158201] .... node #0, CPUs: #1 #2 #3
[ 0.162259] smp: Brought up 1 node, 4 CPUs
[ 0.162259] smpboot: Max logical packages: 1
[ 0.162259] smpboot: Total of 4 processors activated (31124.53 BogoMIPS)
[ 0.164692] devtmpfs: initialized
[ 0.164692] x86/mm: Memory block size: 128MB
[ 0.165397] evm: security.selinux
[ 0.165398] evm: security.SMACK64
[ 0.165398] evm: security.SMACK64EXEC
[ 0.165398] evm: security.SMACK64TRANSMUTE
[ 0.165399] evm: security.SMACK64MMAP
[ 0.165399] evm: security.apparmor
[ 0.165399] evm: security.ima
[ 0.165400] evm: security.capability
[ 0.165414] PM: Registering ACPI NVS region [mem 0xad16c000-0xad7edfff] (6823936 bytes)
[ 0.165414] PM: Registering ACPI NVS region [mem 0xae3e9000-0xae5eefff] (2121728 bytes)
[ 0.165414] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.165414] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.165414] pinctrl core: initialized pinctrl subsystem
[ 0.165414] RTC time: 5:28:56, date: 03/15/23
[ 0.165414] NET: Registered protocol family 16
[ 0.165414] audit: initializing netlink subsys (disabled)
[ 0.165414] audit: type=2000 audit(1678858135.164:1): state=initialized audit_enabled=0 res=1
[ 0.165414] cpuidle: using governor ladder
[ 0.165414] cpuidle: using governor menu
[ 0.165414] ACPI: bus type PCI registered
[ 0.165414] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.165414] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.165414] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.165414] PCI: Using configuration type 1 for base access
[ 0.169315] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.169315] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.169315] ACPI: Added _OSI(Module Device)
[ 0.169315] ACPI: Added _OSI(Processor Device)
[ 0.169315] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.169315] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.169315] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.169315] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.169315] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.169315] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.173638] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.174328] ACPI: Interpreter enabled
[ 0.174346] ACPI: (supports S0 S3 S4 S5)
[ 0.174347] ACPI: Using IOAPIC for interrupt routing
[ 0.174514] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.174801] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.182176] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.182180] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.182395] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[ 0.182606] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.182617] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.182971] PCI host bridge to bus 0000:00
[ 0.182972] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.182973] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.182974] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.182975] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.182976] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.182977] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.182978] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xffffffff window]
[ 0.182979] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.182986] pci 0000:00:00.0: [1022:1410] type 00 class 0x060000
[ 0.183098] pci 0000:00:01.0: [1002:990e] type 00 class 0x030000
[ 0.183110] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff pref]
[ 0.183115] pci 0000:00:01.0: reg 0x14: [io 0xf000-0xf0ff]
[ 0.183121] pci 0000:00:01.0: reg 0x18: [mem 0xfeb00000-0xfeb3ffff]
[ 0.183143] pci 0000:00:01.0: enabling Extended Tags
[ 0.183151] pci 0000:00:01.0: BAR 0: assigned to efifb
[ 0.183172] pci 0000:00:01.0: supports D1 D2
[ 0.183249] pci 0000:00:01.1: [1002:9902] type 00 class 0x040300
[ 0.183260] pci 0000:00:01.1: reg 0x10: [mem 0xfeb44000-0xfeb47fff]
[ 0.183282] pci 0000:00:01.1: enabling Extended Tags
[ 0.183307] pci 0000:00:01.1: supports D1 D2
[ 0.183406] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[ 0.183433] pci 0000:00:10.0: reg 0x10: [mem 0xfeb48000-0xfeb49fff 64bit]
[ 0.183539] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[ 0.183646] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[ 0.183665] pci 0000:00:11.0: reg 0x10: [io 0xf140-0xf147]
[ 0.183674] pci 0000:00:11.0: reg 0x14: [io 0xf130-0xf133]
[ 0.183682] pci 0000:00:11.0: reg 0x18: [io 0xf120-0xf127]
[ 0.183690] pci 0000:00:11.0: reg 0x1c: [io 0xf110-0xf113]
[ 0.183698] pci 0000:00:11.0: reg 0x20: [io 0xf100-0xf10f]
[ 0.183706] pci 0000:00:11.0: reg 0x24: [mem 0xfeb4e000-0xfeb4e7ff]
[ 0.183815] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[ 0.183832] pci 0000:00:12.0: reg 0x10: [mem 0xfeb4d000-0xfeb4dfff]
[ 0.183973] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[ 0.183993] pci 0000:00:12.2: reg 0x10: [mem 0xfeb4c000-0xfeb4c0ff]
[ 0.184073] pci 0000:00:12.2: supports D1 D2
[ 0.184073] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.184156] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[ 0.184173] pci 0000:00:13.0: reg 0x10: [mem 0xfeb4b000-0xfeb4bfff]
[ 0.184306] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[ 0.184326] pci 0000:00:13.2: reg 0x10: [mem 0xfeb4a000-0xfeb4a0ff]
[ 0.184401] pci 0000:00:13.2: supports D1 D2
[ 0.184402] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.184483] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[ 0.184618] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[ 0.184641] pci 0000:00:14.2: reg 0x10: [mem 0xfeb40000-0xfeb43fff 64bit]
[ 0.184703] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.184781] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[ 0.184928] pci 0000:00:14.4: [1022:780f] type 01 class 0x060401
[ 0.185047] pci 0000:00:15.0: [1022:43a0] type 01 class 0x060400
[ 0.185090] pci 0000:00:15.0: enabling Extended Tags
[ 0.185132] pci 0000:00:15.0: supports D1 D2
[ 0.185132] pci 0000:00:15.0: PME# supported from D0 D3hot D3cold
[ 0.185221] pci 0000:00:15.1: [1022:43a1] type 01 class 0x060400
[ 0.185263] pci 0000:00:15.1: enabling Extended Tags
[ 0.185304] pci 0000:00:15.1: supports D1 D2
[ 0.185305] pci 0000:00:15.1: PME# supported from D0 D3hot D3cold
[ 0.185393] pci 0000:00:15.2: [1022:43a2] type 01 class 0x060400
[ 0.185436] pci 0000:00:15.2: enabling Extended Tags
[ 0.185477] pci 0000:00:15.2: supports D1 D2
[ 0.185478] pci 0000:00:15.2: PME# supported from D0 D3hot D3cold
[ 0.185577] pci 0000:00:18.0: [1022:1400] type 00 class 0x060000
[ 0.185671] pci 0000:00:18.1: [1022:1401] type 00 class 0x060000
[ 0.185753] pci 0000:00:18.2: [1022:1402] type 00 class 0x060000
[ 0.185839] pci 0000:00:18.3: [1022:1403] type 00 class 0x060000
[ 0.185931] pci 0000:00:18.4: [1022:1404] type 00 class 0x060000
[ 0.186012] pci 0000:00:18.5: [1022:1405] type 00 class 0x060000
[ 0.186169] pci 0000:00:14.4: PCI bridge to [bus 01] (subtractive decode)
[ 0.186176] pci 0000:00:14.4: bridge window [io 0x0000-0x03af window] (subtractive decode)
[ 0.186177] pci 0000:00:14.4: bridge window [io 0x03e0-0x0cf7 window] (subtractive decode)
[ 0.186178] pci 0000:00:14.4: bridge window [io 0x03b0-0x03df window] (subtractive decode)
[ 0.186179] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.186180] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.186184] pci 0000:00:14.4: bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[ 0.186185] pci 0000:00:14.4: bridge window [mem 0xe0000000-0xffffffff window] (subtractive decode)
[ 0.186226] pci 0000:00:15.0: PCI bridge to [bus 02]
[ 0.186295] pci 0000:03:00.0: [1b21:1142] type 00 class 0x0c0330
[ 0.186330] pci 0000:03:00.0: reg 0x10: [mem 0xfea00000-0xfea07fff 64bit]
[ 0.186469] pci 0000:03:00.0: PME# supported from D3cold
[ 0.196051] pci 0000:00:15.1: PCI bridge to [bus 03]
[ 0.196068] pci 0000:00:15.1: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.196179] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.196211] pci 0000:04:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.196239] pci 0000:04:00.0: reg 0x18: [mem 0xfe900000-0xfe900fff 64bit]
[ 0.196257] pci 0000:04:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.196363] pci 0000:04:00.0: supports D1 D2
[ 0.196364] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.208053] pci 0000:00:15.2: PCI bridge to [bus 04]
[ 0.208067] pci 0000:00:15.2: bridge window [io 0xe000-0xefff]
[ 0.208070] pci 0000:00:15.2: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.208075] pci 0000:00:15.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.208733] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.208809] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.208888] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.208966] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 10 11 14 15) *0
[ 0.209029] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.209079] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.209128] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.209177] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.209584] SCSI subsystem initialized
[ 0.209595] libata version 3.00 loaded.
[ 0.209595] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[ 0.209595] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.209595] pci 0000:00:01.0: vgaarb: bridge control possible
[ 0.209595] vgaarb: loaded
[ 0.209595] ACPI: bus type USB registered
[ 0.209595] usbcore: registered new interface driver usbfs
[ 0.209595] usbcore: registered new interface driver hub
[ 0.209595] usbcore: registered new device driver usb
[ 0.209595] EDAC MC: Ver: 3.0.0
[ 0.209595] Registered efivars operations
[ 0.209595] PCI: Using ACPI for IRQ routing
[ 0.212031] PCI: pci_cache_line_size set to 64 bytes
[ 0.212084] e820: reserve RAM buffer [mem 0x8a3aa018-0x8bffffff]
[ 0.212085] e820: reserve RAM buffer [mem 0x8a3b8018-0x8bffffff]
[ 0.212085] e820: reserve RAM buffer [mem 0xa1a94000-0xa3ffffff]
[ 0.212086] e820: reserve RAM buffer [mem 0xad12c000-0xafffffff]
[ 0.212087] e820: reserve RAM buffer [mem 0xae3e9000-0xafffffff]
[ 0.212087] e820: reserve RAM buffer [mem 0xaea33000-0xafffffff]
[ 0.212088] e820: reserve RAM buffer [mem 0xaf000000-0xafffffff]
[ 0.212089] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[ 0.212175] NetLabel: Initializing
[ 0.212175] NetLabel: domain hash size = 128
[ 0.212175] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.212187] NetLabel: unlabeled traffic allowed by default
[ 0.212209] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.212209] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.214134] clocksource: Switched to clocksource hpet
[ 0.224791] VFS: Disk quotas dquot_6.6.0
[ 0.224810] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.224924] AppArmor: AppArmor Filesystem Enabled
[ 0.224951] pnp: PnP ACPI init
[ 0.225099] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.225103] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.225170] system 00:01: [mem 0xb0000000-0xdfffffff] has been reserved
[ 0.225173] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225235] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225432] system 00:03: [io 0x0300-0x031f] has been reserved
[ 0.225433] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.225434] system 00:03: [io 0x0230-0x023f] has been reserved
[ 0.225437] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225491] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.225623] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.225627] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225664] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225952] pnp 00:07: [dma 0 disabled]
[ 0.225994] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.226266] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.226267] system 00:08: [io 0x040b] has been reserved
[ 0.226268] system 00:08: [io 0x04d6] has been reserved
[ 0.226269] system 00:08: [io 0x0c00-0x0c01] has been reserved
[ 0.226270] system 00:08: [io 0x0c14] has been reserved
[ 0.226271] system 00:08: [io 0x0c50-0x0c51] has been reserved
[ 0.226272] system 00:08: [io 0x0c52] has been reserved
[ 0.226273] system 00:08: [io 0x0c6c] has been reserved
[ 0.226274] system 00:08: [io 0x0c6f] has been reserved
[ 0.226275] system 00:08: [io 0x0cd0-0x0cd1] has been reserved
[ 0.226276] system 00:08: [io 0x0cd2-0x0cd3] has been reserved
[ 0.226277] system 00:08: [io 0x0cd4-0x0cd5] has been reserved
[ 0.226278] system 00:08: [io 0x0cd6-0x0cd7] has been reserved
[ 0.226279] system 00:08: [io 0x0cd8-0x0cdf] has been reserved
[ 0.226280] system 00:08: [io 0x0800-0x089f] has been reserved
[ 0.226281] system 00:08: [io 0x0b20-0x0b3f] has been reserved
[ 0.226282] system 00:08: [io 0x0900-0x090f] has been reserved
[ 0.226283] system 00:08: [io 0x0910-0x091f] has been reserved
[ 0.226284] system 00:08: [io 0xfe00-0xfefe] has been reserved
[ 0.226286] system 00:08: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.226287] system 00:08: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.226289] system 00:08: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.226290] system 00:08: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.226291] system 00:08: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.226292] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[ 0.226295] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.226501] pnp: PnP ACPI: found 9 devices
[ 0.233074] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.233083] pci 0000:00:14.4: PCI bridge to [bus 01]
[ 0.233095] pci 0000:00:15.0: PCI bridge to [bus 02]
[ 0.233103] pci 0000:00:15.1: PCI bridge to [bus 03]
[ 0.233107] pci 0000:00:15.1: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.233113] pci 0000:00:15.2: PCI bridge to [bus 04]
[ 0.233115] pci 0000:00:15.2: bridge window [io 0xe000-0xefff]
[ 0.233119] pci 0000:00:15.2: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.233121] pci 0000:00:15.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.233126] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.233127] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.233128] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.233129] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.233131] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.233132] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.233133] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xffffffff window]
[ 0.233134] pci_bus 0000:01: resource 4 [io 0x0000-0x03af window]
[ 0.233135] pci_bus 0000:01: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.233135] pci_bus 0000:01: resource 6 [io 0x03b0-0x03df window]
[ 0.233136] pci_bus 0000:01: resource 7 [io 0x0d00-0xffff window]
[ 0.233137] pci_bus 0000:01: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.233138] pci_bus 0000:01: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.233139] pci_bus 0000:01: resource 10 [mem 0xe0000000-0xffffffff window]
[ 0.233140] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.233141] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.233142] pci_bus 0000:04: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.233143] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.233208] NET: Registered protocol family 2
[ 0.233622] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.235986] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.236272] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.236470] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.236531] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.236593] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.236692] NET: Registered protocol family 1
[ 0.236708] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.236712] pci 0000:00:01.1: Linked as a consumer to 0000:00:01.0
[ 0.236713] pci 0000:00:01.1: D0 power state depends on 0000:00:01.0
[ 0.348299] pci 0000:00:12.2: PME# does not work under D3, disabling it
[ 0.456282] pci 0000:00:13.2: PME# does not work under D3, disabling it
[ 0.456486] PCI: CLS 64 bytes, default 64
[ 0.456526] Unpacking initramfs...
[ 1.130787] Freeing initrd memory: 64556K
[ 1.130871] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.130872] software IO TLB: mapped [mem 0x9bb33000-0x9fb33000] (64MB)
[ 1.130916] amd_uncore: AMD NB counters detected
[ 1.131063] LVT offset 0 assigned for vector 0x400
[ 1.131105] perf: AMD IBS detected (0x000000ff)
[ 1.131186] Scanning for low memory corruption every 60 seconds
[ 1.131806] Initialise system trusted keyrings
[ 1.131820] Key type blacklist registered
[ 1.131926] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 1.133187] zbud: loaded
[ 1.133728] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.133953] fuse init (API version 7.26)
[ 1.135608] Key type asymmetric registered
[ 1.135610] Asymmetric key parser 'x509' registered
[ 1.135666] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.135694] io scheduler noop registered
[ 1.135695] io scheduler deadline registered
[ 1.135724] io scheduler cfq registered (default)
[ 1.136258] efifb: probing for efifb
[ 1.136271] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[ 1.136272] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 1.136272] efifb: scrolling: redraw
[ 1.136273] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.136395] Console: switching to colour frame buffer device 128x48
[ 1.136408] fb0: EFI VGA frame buffer device
[ 1.136485] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.136492] ACPI: Power Button [PWRB]
[ 1.136522] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.136549] ACPI: Power Button [PWRF]
[ 1.137061] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.157525] 00:07: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.159492] Linux agpgart interface v0.103
[ 1.161187] loop: module loaded
[ 1.161352] tun: Universal TUN/TAP device driver, 1.6
[ 1.161424] PPP generic driver version 2.4.2
[ 1.161464] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.161466] ehci-pci: EHCI PCI platform driver
[ 1.161584] QUIRK: Enable AMD PLL fix
[ 1.161603] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 1.161608] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.161611] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.161619] ehci-pci 0000:00:12.2: debug port 1
[ 1.161669] ehci-pci 0000:00:12.2: irq 17, io mem 0xfeb4c000
[ 1.176096] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.176170] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.176172] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.176173] usb usb1: Product: EHCI Host Controller
[ 1.176174] usb usb1: Manufacturer: Linux 4.15.0-206-generic ehci_hcd
[ 1.176175] usb usb1: SerialNumber: 0000:00:12.2
[ 1.176303] hub 1-0:1.0: USB hub found
[ 1.176308] hub 1-0:1.0: 5 ports detected
[ 1.176573] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 1.176577] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 1.176580] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.176588] ehci-pci 0000:00:13.2: debug port 1
[ 1.176615] ehci-pci 0000:00:13.2: irq 17, io mem 0xfeb4a000
[ 1.192099] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.192168] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.192169] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.192170] usb usb2: Product: EHCI Host Controller
[ 1.192171] usb usb2: Manufacturer: Linux 4.15.0-206-generic ehci_hcd
[ 1.192172] usb usb2: SerialNumber: 0000:00:13.2
[ 1.192302] hub 2-0:1.0: USB hub found
[ 1.192307] hub 2-0:1.0: 5 ports detected
[ 1.192439] ehci-platform: EHCI generic platform driver
[ 1.192452] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.192454] ohci-pci: OHCI PCI platform driver
[ 1.192613] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 1.192617] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 3
[ 1.192648] ohci-pci 0000:00:12.0: irq 18, io mem 0xfeb4d000
[ 1.256127] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.256129] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.256130] usb usb3: Product: OHCI PCI host controller
[ 1.256131] usb usb3: Manufacturer: Linux 4.15.0-206-generic ohci_hcd
[ 1.256132] usb usb3: SerialNumber: 0000:00:12.0
[ 1.256329] hub 3-0:1.0: USB hub found
[ 1.256336] hub 3-0:1.0: 5 ports detected
[ 1.256604] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 1.256608] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 4
[ 1.256631] ohci-pci 0000:00:13.0: irq 18, io mem 0xfeb4b000
[ 1.320118] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.320121] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.320122] usb usb4: Product: OHCI PCI host controller
[ 1.320122] usb usb4: Manufacturer: Linux 4.15.0-206-generic ohci_hcd
[ 1.320123] usb usb4: SerialNumber: 0000:00:13.0
[ 1.320318] hub 4-0:1.0: USB hub found
[ 1.320325] hub 4-0:1.0: 5 ports detected
[ 1.320457] ohci-platform: OHCI generic platform driver
[ 1.320469] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.320650] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.320654] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 5
[ 1.320835] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000418
[ 1.321049] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.321050] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.321051] usb usb5: Product: xHCI Host Controller
[ 1.321052] usb usb5: Manufacturer: Linux 4.15.0-206-generic xhci-hcd
[ 1.321053] usb usb5: SerialNumber: 0000:00:10.0
[ 1.321202] hub 5-0:1.0: USB hub found
[ 1.321213] hub 5-0:1.0: 2 ports detected
[ 1.321285] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.321290] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 6
[ 1.321292] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 1.324251] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.324271] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.324272] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.324273] usb usb6: Product: xHCI Host Controller
[ 1.324273] usb usb6: Manufacturer: Linux 4.15.0-206-generic xhci-hcd
[ 1.324274] usb usb6: SerialNumber: 0000:00:10.0
[ 1.324377] hub 6-0:1.0: USB hub found
[ 1.324386] hub 6-0:1.0: 2 ports detected
[ 1.324505] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.324510] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 7
[ 1.384950] xhci_hcd 0000:03:00.0: hcc params 0x0200e080 hci version 0x100 quirks 0x0000000010800410
[ 1.385159] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.385160] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.385161] usb usb7: Product: xHCI Host Controller
[ 1.385162] usb usb7: Manufacturer: Linux 4.15.0-206-generic xhci-hcd
[ 1.385163] usb usb7: SerialNumber: 0000:03:00.0
[ 1.385317] hub 7-0:1.0: USB hub found
[ 1.385324] hub 7-0:1.0: 2 ports detected
[ 1.385399] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.385401] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 8
[ 1.385403] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[ 1.385444] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.385461] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.385462] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.385463] usb usb8: Product: xHCI Host Controller
[ 1.385464] usb usb8: Manufacturer: Linux 4.15.0-206-generic xhci-hcd
[ 1.385464] usb usb8: SerialNumber: 0000:03:00.0
[ 1.385545] hub 8-0:1.0: USB hub found
[ 1.385551] hub 8-0:1.0: 2 ports detected
[ 1.385653] i8042: PNP: No PS/2 controller found.
[ 1.385716] mousedev: PS/2 mouse device common for all mice
[ 1.385838] rtc_cmos 00:04: RTC can wake from S4
[ 1.385938] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.385959] rtc_cmos 00:04: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.385963] i2c /dev entries driver
[ 1.386013] device-mapper: uevent: version 1.0.3
[ 1.386071] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 1.386130] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.386132] EFI Variables Facility v0.08 2004-May-17
[ 1.392770] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[ 1.392929] NET: Registered protocol family 10
[ 1.401750] Segment Routing with IPv6
[ 1.401774] NET: Registered protocol family 17
[ 1.401823] Key type dns_resolver registered
[ 1.402089] mce: Using 7 MCE banks
[ 1.402107] RAS: Correctable Errors collector initialized.
[ 1.402140] microcode: CPU0: patch_level=0x06001119
[ 1.402147] microcode: CPU1: patch_level=0x06001119
[ 1.402155] microcode: CPU2: patch_level=0x06001119
[ 1.402162] microcode: CPU3: patch_level=0x06001119
[ 1.402197] microcode: Microcode Update Driver: v2.2.
[ 1.402208] sched_clock: Marking stable (1402193795, 0)->(1379363255, 22830540)
[ 1.402415] registered taskstats version 1
[ 1.402423] Loading compiled-in X.509 certificates
[ 1.407032] Loaded X.509 cert 'Build time autogenerated kernel key: 4d405f87ce750406625b929cd2e51cc76ab5bcf4'
[ 1.407733] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 1.408466] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 1.408468] blacklist: Loading compiled-in revocation X.509 certificates
[ 1.408486] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 1.408502] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[ 1.408518] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[ 1.408533] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[ 1.408551] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[ 1.408568] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[ 1.408583] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[ 1.408598] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[ 1.413062] Loaded UEFI:db cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2' linked to secondary sys keyring
[ 1.413290] Loaded UEFI:db cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071' linked to secondary sys keyring
[ 1.413310] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring
[ 1.413331] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring
[ 1.413547] Loaded UEFI:db cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63' linked to secondary sys keyring
[ 1.414299] Loaded UEFI:MokListRT (MOKvar table) cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63' linked to secondary sys keyring
[ 1.414324] zswap: loaded using pool lzo/zbud
[ 1.422516] Key type big_key registered
[ 1.422523] Key type trusted registered
[ 1.426211] Key type encrypted registered
[ 1.426215] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.426218] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 1.426226] ima: Allocated hash algorithm: sha1
[ 1.426240] evm: HMAC attrs: 0x1
[ 1.426513] Magic number: 15:561:466
[ 1.426531] cache: hash matches
[ 1.426532] cache: hash matches
[ 1.426533] cache: hash matches
[ 1.426534] cache: hash matches
[ 1.426632] rtc_cmos 00:04: setting system clock to 2023-03-15 05:28:57 UTC (1678858137)
[ 1.426822] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.426972] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.426972] EDD information not available.
[ 1.427011] Lockdown: Hibernation is restricted; see man kernel_lockdown.7
[ 1.576071] usb 5-2: new high-speed USB device number 2 using xhci_hcd
[ 1.660065] usb 3-2: new low-speed USB device number 2 using ohci-pci
[ 1.708062] usb 7-1: new low-speed USB device number 2 using xhci_hcd
[ 1.737045] usb 5-2: New USB device found, idVendor=05e3, idProduct=0745
[ 1.737048] usb 5-2: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 1.737049] usb 5-2: Product: USB Storage
[ 1.737050] usb 5-2: SerialNumber: 000000000903
[ 1.857113] usb 3-2: New USB device found, idVendor=0461, idProduct=0010
[ 1.857115] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.857116] usb 3-2: Product: USB Keyboard
[ 1.857117] usb 3-2: Manufacturer: NOVATEK
[ 1.921478] Freeing unused kernel image memory: 2480K
[ 1.936091] Write protecting the kernel read-only data: 20480k
[ 1.937555] Freeing unused kernel image memory: 2008K
[ 1.938076] Freeing unused kernel image memory: 1820K
[ 1.945745] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.955559] usb 7-1: New USB device found, idVendor=046d, idProduct=c077
[ 1.955561] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.955563] usb 7-1: Product: USB Optical Mouse
[ 1.955564] usb 7-1: Manufacturer: Logitech
[ 2.013472] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 2.013624] ACPI Error: [AFN7] Namespace lookup failure, AE_NOT_FOUND (20170831/psargs-364)
[ 2.013633]
Initialized Local Variables for Method [_BCM]:
[ 2.013634] Local0: (ptrval) <Obj> Integer 00000000000000FF
[ 2.013638] Local1: (ptrval) <Obj> Integer 0000000000000000
[ 2.013643] Initialized Arguments for Method [_BCM]: (1 arguments defined for method invocation)
[ 2.013644] Arg0: (ptrval) <Obj> Integer 0000000000000064
[ 2.013649] ACPI Error: Method parse/execution failed \_SB.PCI0.VGA.LCD._BCM, AE_NOT_FOUND (20170831/psparse-550)
[ 2.013658] ACPI Error: Evaluating _BCM failed (20170831/video-370)
[ 2.013738] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2
[ 2.027212] ahci 0000:00:11.0: version 3.0
[ 2.027531] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 2.027534] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio
[ 2.028795] scsi host0: ahci
[ 2.028914] scsi host1: ahci
[ 2.029011] scsi host2: ahci
[ 2.029109] scsi host3: ahci
[ 2.029201] scsi host4: ahci
[ 2.029288] scsi host5: ahci
[ 2.029331] ata1: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e100 irq 34
[ 2.029333] ata2: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e180 irq 34
[ 2.029335] ata3: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e200 irq 34
[ 2.029337] ata4: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e280 irq 34
[ 2.029338] ata5: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e300 irq 34
[ 2.029340] ata6: SATA max UDMA/133 abar m2048@0xfeb4e000 port 0xfeb4e380 irq 34
[ 2.049701] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.049703] usb-storage 5-2:1.0: USB Mass Storage device detected
[ 2.050267] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.050268] piix4_smbus 0000:00:14.0: Using register 0x2e for SMBus port selection
[ 2.050536] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 2.051603] scsi host6: usb-storage 5-2:1.0
[ 2.051700] usbcore: registered new interface driver usb-storage
[ 2.064933] usbcore: registered new interface driver usbhid
[ 2.064934] usbhid: USB HID core driver
[ 2.139957] tsc: Refined TSC clocksource calibration: 3890.258 MHz
[ 2.139962] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x7026d05ed32, max_idle_ns: 881590578069 ns
[ 2.172473] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:12.0/usb3/3-2/3-2:1.0/0003:0461:0010.0001/input/input3
[ 2.232191] hid-generic 0003:0461:0010.0001: input,hidraw0: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:12.0-2/input0
[ 2.232370] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:12.0/usb3/3-2/3-2:1.1/0003:0461:0010.0002/input/input4
[ 2.292171] hid-generic 0003:0461:0010.0002: input,hidraw1: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:12.0-2/input1
[ 2.292317] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:15.1/0000:03:00.0/usb7/7-1/7-1:1.0/0003:046D:C077.0003/input/input5
[ 2.292420] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:03:00.0-1/input0
[ 2.343645] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.343668] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.343696] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.343722] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.504061] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.504079] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.505161] ata1.00: ATA-9: WDC WD10EZEX-60M2NA0, 03.01A03, max UDMA/100
[ 2.505163] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.506348] ata1.00: configured for UDMA/100
[ 2.506472] ata2.00: ATAPI: ASUS DRW-24F1MT, 1.00, max UDMA/100
[ 2.506632] scsi 0:0:0:0: Direct-Access ATA WDC WD10EZEX-60M 1A03 PQ: 0 ANSI: 5
[ 2.506878] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.506976] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.506979] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.506998] sd 0:0:0:0: [sda] Write Protect is off
[ 2.507000] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.507035] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.507334] ata2.00: configured for UDMA/100
[ 2.509205] scsi 1:0:0:0: CD-ROM ASUS DRW-24F1MT 1.00 PQ: 0 ANSI: 5
[ 2.567839] sda: sda1 sda2
[ 2.568292] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.580075] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.580077] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.580227] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.580300] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.581966] usbcore: registered new interface driver uas
[ 2.582553] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 2.592920] r8169 0000:04:00.0 eth0: RTL8168g/8111g at 0x (ptrval), 30:5a:3a:83:21:43, XID 0c000800 IRQ 35
[ 2.592922] r8169 0000:04:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 2.594909] r8169 0000:04:00.0 enp4s0: renamed from eth0
[ 2.608142] [drm] radeon kernel modesetting enabled.
[ 2.608183] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[ 2.608184] fb: switching to radeondrmfb from EFI VGA
[ 2.608205] Console: switching to colour dummy device 80x25
[ 2.608590] [drm] initializing kernel modesetting (ARUBA 0x1002:0x990E 0x1043:0x8526 0x00).
[ 2.608640] ATOM BIOS: 113
[ 2.608694] radeon 0000:00:01.0: VRAM: 768M 0x0000000000000000 - 0x000000002FFFFFFF (768M used)
[ 2.608696] radeon 0000:00:01.0: GTT: 1024M 0x0000000030000000 - 0x000000006FFFFFFF
[ 2.608698] [drm] Detected VRAM RAM=768M, BAR=256M
[ 2.608698] [drm] RAM width 64bits DDR
[ 2.608773] [TTM] Zone kernel: Available graphics memory: 7795708 kiB
[ 2.608775] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 2.608775] [TTM] Initializing pool allocator
[ 2.608779] [TTM] Initializing DMA pool allocator
[ 2.608797] [drm] radeon: 768M of VRAM memory ready
[ 2.608798] [drm] radeon: 1024M of GTT memory ready.
[ 2.608807] [drm] Loading ARUBA Microcode
[ 2.608858] [drm] Internal thermal controller without fan control
[ 2.608987] [drm] radeon: dpm initialized
[ 2.609907] [drm] Found VCE firmware/feedback version 50.0.1 / 17!
[ 2.609913] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.640305] [drm] PCIE GART of 1024M enabled (table at 0x00000000001D6000).
[ 2.640432] radeon 0000:00:01.0: WB enabled
[ 2.640435] radeon 0000:00:01.0: fence driver on ring 0 use gpu addr 0x0000000030000c00 and cpu addr 0x (ptrval)
[ 2.640812] radeon 0000:00:01.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0x (ptrval)
[ 2.660835] radeon 0000:00:01.0: fence driver on ring 6 use gpu addr 0x0000000030000c18 and cpu addr 0x (ptrval)
[ 2.660836] radeon 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000030000c1c and cpu addr 0x (ptrval)
[ 2.660837] radeon 0000:00:01.0: fence driver on ring 1 use gpu addr 0x0000000030000c04 and cpu addr 0x (ptrval)
[ 2.660839] radeon 0000:00:01.0: fence driver on ring 2 use gpu addr 0x0000000030000c08 and cpu addr 0x (ptrval)
[ 2.660840] radeon 0000:00:01.0: fence driver on ring 3 use gpu addr 0x0000000030000c0c and cpu addr 0x (ptrval)
[ 2.660841] radeon 0000:00:01.0: fence driver on ring 4 use gpu addr 0x0000000030000c10 and cpu addr 0x (ptrval)
[ 2.660842] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.660842] [drm] Driver supports precise vblank timestamp query.
[ 2.660843] radeon 0000:00:01.0: radeon: MSI limited to 32-bit
[ 2.660879] radeon 0000:00:01.0: radeon: using MSI.
[ 2.660905] [drm] radeon: irq initialized.
[ 2.679352] [drm] ring test on 0 succeeded in 2 usecs
[ 2.679358] [drm] ring test on 3 succeeded in 3 usecs
[ 2.679363] [drm] ring test on 4 succeeded in 3 usecs
[ 2.725042] [drm] ring test on 5 succeeded in 1 usecs
[ 2.744897] [drm] UVD initialized successfully.
[ 2.851273] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.854103] [drm] ring test on 6 succeeded in 17 usecs
[ 2.854112] [drm] ring test on 7 succeeded in 3 usecs
[ 2.854112] [drm] VCE initialized successfully.
[ 2.854493] [drm] ib test on ring 0 succeeded in 0 usecs
[ 2.854550] [drm] ib test on ring 3 succeeded in 0 usecs
[ 2.854605] [drm] ib test on ring 4 succeeded in 0 usecs
[ 2.865426] random: lvm: uninitialized urandom read (2 bytes read)
[ 3.070004] scsi 6:0:0:0: Direct-Access Generic STORAGE DEVICE 0903 PQ: 0 ANSI: 6
[ 3.070307] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 3.072515] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3.164194] clocksource: Switched to clocksource tsc
[ 3.388185] [drm] ib test on ring 5 succeeded
[ 3.932214] [drm] ib test on ring 6 succeeded
[ 4.444191] [drm] ib test on ring 7 succeeded
[ 4.444772] [drm] Radeon Display Connectors
[ 4.444773] [drm] Connector 0:
[ 4.444773] [drm] HDMI-A-1
[ 4.444774] [drm] HPD1
[ 4.444775] [drm] DDC: 0x6530 0x6530 0x6534 0x6534 0x6538 0x6538 0x653c 0x653c
[ 4.444775] [drm] Encoders:
[ 4.444776] [drm] DFP1: INTERNAL_UNIPHY2
[ 4.444776] [drm] Connector 1:
[ 4.444776] [drm] VGA-1
[ 4.444777] [drm] HPD2
[ 4.444778] [drm] DDC: 0x6540 0x6540 0x6544 0x6544 0x6548 0x6548 0x654c 0x654c
[ 4.444778] [drm] Encoders:
[ 4.444778] [drm] CRT1: INTERNAL_UNIPHY2
[ 4.444779] [drm] CRT1: NUTMEG
[ 4.444779] [drm] Connector 2:
[ 4.444779] [drm] DVI-D-1
[ 4.444780] [drm] HPD3
[ 4.444781] [drm] DDC: 0x6550 0x6550 0x6554 0x6554 0x6558 0x6558 0x655c 0x655c
[ 4.444781] [drm] Encoders:
[ 4.444781] [drm] DFP2: INTERNAL_UNIPHY
[ 4.682829] [drm] fb mappable at 0xE03DA000
[ 4.682830] [drm] vram apper at 0xE0000000
[ 4.682831] [drm] size 7299072
[ 4.682831] [drm] fb depth is 24
[ 4.682831] [drm] pitch is 6912
[ 4.682918] fbcon: radeondrmfb (fb0) is primary device
[ 4.682971] Console: switching to colour frame buffer device 210x65
[ 4.682995] radeon 0000:00:01.0: fb0: radeondrmfb frame buffer device
[ 4.696181] [drm] Initialized radeon 2.50.0 20080528 for 0000:00:01.0 on minor 0
[ 5.326738] random: lvm: uninitialized urandom read (4 bytes read)
[ 5.391962] raid6: sse2x1 gen() 6735 MB/s
[ 5.439959] raid6: sse2x1 xor() 4372 MB/s
[ 5.487958] raid6: sse2x2 gen() 10126 MB/s
[ 5.535956] raid6: sse2x2 xor() 7116 MB/s
[ 5.583959] raid6: sse2x4 gen() 12604 MB/s
[ 5.631959] raid6: sse2x4 xor() 6677 MB/s
[ 5.631960] raid6: using algorithm sse2x4 gen() 12604 MB/s
[ 5.631961] raid6: .... xor() 6677 MB/s, rmw enabled
[ 5.631961] raid6: using ssse3x2 recovery algorithm
[ 5.634851] xor: automatically using best checksumming function avx
[ 5.652115] Btrfs loaded, crc32c=crc32c-intel
[ 5.940982] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 7.918611] random: crng init done
[ 7.977499] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.067053] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.084266] systemd[1]: Detected architecture x86-64.
[ 8.087296] systemd[1]: Set hostname to <christelaurent-System-Product-Name>.
[ 8.090144] Lockdown: /dev/mem,kmem,port is restricted; see man kernel_lockdown.7
[ 10.319887] systemd[1]: Reached target Remote File Systems.
[ 10.320139] systemd[1]: Created slice System Slice.
[ 10.320211] systemd[1]: Listening on LVM2 poll daemon socket.
[ 10.320270] systemd[1]: Listening on Journal Socket.
[ 10.320892] systemd[1]: Starting Uncomplicated firewall...
[ 10.321610] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 10.322389] systemd[1]: Started Read required files in advance.
[ 10.736455] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[ 10.768111] systemd-journald[422]: Received request to flush runtime journal from PID 1
[ 10.908575] PKCS#7 signature not signed with a trusted key
[ 10.908580] Lockdown: Loading of unsigned modules is restricted; see man kernel_lockdown.7
[ 11.009792] PKCS#7 signature not signed with a trusted key
[ 17.685082] lp: driver loaded but no devices found
[ 17.693179] ppdev: user-space parallel port driver
[ 19.867269] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 20.136415] asus_wmi: ASUS WMI generic driver loaded
[ 20.149521] asus_wmi: Initialization: 0x0
[ 20.149559] asus_wmi: BIOS WMI version: 0.9
[ 20.149635] asus_wmi: SFUN value: 0x0
[ 20.150236] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input6
[ 20.150359] asus_wmi: Number of fans: 1
[ 20.256036] AVX version of gcm_enc/dec engaged.
[ 20.256038] AES CTR mode by8 optimization enabled
[ 21.515777] snd_hda_intel 0000:00:01.1: enabling device (0000 -> 0002)
[ 21.515904] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 21.525061] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input7
[ 21.565769] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 21.565771] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 21.565772] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 21.565773] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 21.565774] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x11/0x0
[ 21.565775] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 21.565777] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 21.565778] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 21.565779] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 21.578550] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input8
[ 21.578611] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input9
[ 21.578666] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:14.2/sound/card1/input10
[ 21.578722] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:14.2/sound/card1/input11
[ 21.578778] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input12
[ 21.594466] kvm: Nested Virtualization enabled
[ 21.594468] kvm: Nested Paging enabled
[ 21.598917] MCE: In-kernel MCE decoding enabled.
[ 21.600401] EDAC amd64: Node 0: DRAM ECC disabled.
[ 21.600402] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
(Note that use of the override may cause unknown side effects.)
[ 21.644504] EDAC amd64: Node 0: DRAM ECC disabled.
[ 21.644505] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 21.680461] EDAC amd64: Node 0: DRAM ECC disabled.
[ 21.680462] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 21.712486] EDAC amd64: Node 0: DRAM ECC disabled.
[ 21.712488] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 28.929523] Adding 15929340k swap on /dev/mapper/mint--vg-swap_1. Priority:-2 extents:1 across:15929340k FS
[ 29.832135] audit: type=1400 audit(1678858165.901:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=815 comm="apparmor_parser"
[ 29.832140] audit: type=1400 audit(1678858165.901:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=815 comm="apparmor_parser"
[ 29.832143] audit: type=1400 audit(1678858165.901:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=815 comm="apparmor_parser"
[ 29.833172] audit: type=1400 audit(1678858165.901:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=812 comm="apparmor_parser"
[ 29.833176] audit: type=1400 audit(1678858165.901:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=812 comm="apparmor_parser"
[ 29.833178] audit: type=1400 audit(1678858165.901:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=812 comm="apparmor_parser"
[ 29.833180] audit: type=1400 audit(1678858165.901:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=812 comm="apparmor_parser"
[ 29.833377] audit: type=1400 audit(1678858165.901:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=811 comm="apparmor_parser"
[ 29.833381] audit: type=1400 audit(1678858165.901:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=811 comm="apparmor_parser"
[ 29.833563] audit: type=1400 audit(1678858165.901:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=816 comm="apparmor_parser"
[ 38.643458] IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
[ 39.294284] r8169 0000:04:00.0 enp4s0: link down
[ 39.294287] r8169 0000:04:00.0 enp4s0: link down
[ 39.294395] IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
[ 39.907518] Lockdown: ioperm is restricted; see man kernel_lockdown.7
[ 42.605850] kauditd_printk_skb: 47 callbacks suppressed
[ 42.605852] audit: type=1400 audit(1678858178.673:59): apparmor="ALLOWED" operation="open" profile="snap.anbox.container-manager" name="/proc/1137/attr/current" pid=1137 comm="cat" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 42.606441] audit: type=1400 audit(1678858178.673:60): apparmor="ALLOWED" operation="exec" profile="snap.anbox.container-manager" name="/usr/sbin/aa-exec" pid=1048 comm="container-manag" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="snap.anbox.container-manager//null-/usr/sbin/aa-exec"
[ 42.634428] audit: type=1400 audit(1678858178.701:61): apparmor="ALLOWED" operation="file_mmap" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/usr/sbin/aa-exec" pid=1048 comm="aa-exec" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[ 42.634437] audit: type=1400 audit(1678858178.701:62): apparmor="ALLOWED" operation="file_mmap" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/lib/x86_64-linux-gnu/ld-2.23.so" pid=1048 comm="aa-exec" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[ 42.634660] audit: type=1400 audit(1678858178.701:63): apparmor="ALLOWED" operation="open" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/etc/ld.so.cache" pid=1048 comm="aa-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 42.634703] audit: type=1400 audit(1678858178.701:64): apparmor="ALLOWED" operation="open" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/lib/x86_64-linux-gnu/libpthread-2.23.so" pid=1048 comm="aa-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 42.634715] audit: type=1400 audit(1678858178.701:65): apparmor="ALLOWED" operation="file_mmap" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/lib/x86_64-linux-gnu/libpthread-2.23.so" pid=1048 comm="aa-exec" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[ 42.634802] audit: type=1400 audit(1678858178.701:66): apparmor="ALLOWED" operation="open" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/lib/x86_64-linux-gnu/libc-2.23.so" pid=1048 comm="aa-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 42.634813] audit: type=1400 audit(1678858178.701:67): apparmor="ALLOWED" operation="file_mmap" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/lib/x86_64-linux-gnu/libc-2.23.so" pid=1048 comm="aa-exec" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[ 42.635145] audit: type=1400 audit(1678858178.701:68): apparmor="ALLOWED" operation="open" profile="snap.anbox.container-manager//null-/usr/sbin/aa-exec" name="/proc/1048/attr/exec" pid=1048 comm="aa-exec" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[ 42.769173] r8169 0000:04:00.0 enp4s0: link up
[ 42.769186] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[ 46.150853] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 46.560158] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 47.212621] PKCS#7 signature not signed with a trusted key
[ 47.214061] PKCS#7 signature not signed with a trusted key
[ 48.958542] kauditd_printk_skb: 3 callbacks suppressed
[ 48.958545] audit: type=1326 audit(1678858185.025:72): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1048 comm="anbox" exe="/snap/anbox/186/usr/bin/anbox" sig=0 arch=c000003e syscall=165 compat=0 ip=0x7f5e042a6aba code=0x7ffc0000
[ 49.173546] audit: type=1326 audit(1678858185.241:73): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1048 comm="anbox" exe="/snap/anbox/186/usr/bin/anbox" sig=0 arch=c000003e syscall=165 compat=0 ip=0x7f5e042a6aba code=0x7ffc0000
[ 49.363865] audit: type=1326 audit(1678858185.433:74): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1048 comm="anbox" exe="/snap/anbox/186/usr/bin/anbox" sig=0 arch=c000003e syscall=165 compat=0 ip=0x7f5e042a6aba code=0x7ffc0000
[10085.536313] sd 6:0:0:0: [sdb] 121634816 512-byte logical blocks: (62.3 GB/58.0 GiB)
[10085.544417] sdb: sdb1
[11249.838201] audit: type=1400 audit(1678869385.641:75): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=8093 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11249.840294] audit: type=1400 audit(1678869385.645:76): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=8093 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11249.892160] audit: type=1400 audit(1678869385.697:77): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=8093 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11249.893793] audit: type=1400 audit(1678869385.697:78): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=8093 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11249.895362] audit: type=1400 audit(1678869385.701:79): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=8093 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11249.896918] audit: type=1400 audit(1678869385.701:80): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.cache/mesa_shader_cache/index" pid=8093 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[11252.783697] audit: type=1400 audit(1678869388.590:81): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/profiles.ini" pid=8092 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11252.785391] audit: type=1400 audit(1678869388.590:82): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/secmod.db" pid=8092 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11252.805584] audit: type=1400 audit(1678869388.610:83): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/cert8.db" pid=8092 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[11252.811319] audit: type=1400 audit(1678869388.618:84): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/key3.db" pid=8092 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[12945.582672] audit: type=1400 audit(1678871081.428:85): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11033 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12945.584444] audit: type=1400 audit(1678871081.428:86): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11033 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12945.642715] audit: type=1400 audit(1678871081.488:87): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11033 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12945.645202] audit: type=1400 audit(1678871081.492:88): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11033 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12945.647313] audit: type=1400 audit(1678871081.492:89): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11033 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12945.649120] audit: type=1400 audit(1678871081.496:90): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.cache/mesa_shader_cache/index" pid=11033 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[12946.212600] audit: type=1400 audit(1678871082.056:91): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/profiles.ini" pid=11032 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[12946.213814] audit: type=1400 audit(1678871082.060:92): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/secmod.db" pid=11032 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[12946.214287] audit: type=1400 audit(1678871082.060:93): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/cert8.db" pid=11032 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[12946.214296] audit: type=1400 audit(1678871082.060:94): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/key3.db" pid=11032 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[13262.073670] audit: type=1400 audit(1678871397.928:95): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11147 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[13262.075819] audit: type=1400 audit(1678871397.928:96): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11147 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[13262.137905] audit: type=1400 audit(1678871397.992:97): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11147 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[13262.139582] audit: type=1400 audit(1678871397.992:98): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11147 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[13262.141448] audit: type=1400 audit(1678871397.996:99): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=11147 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[13262.143279] audit: type=1400 audit(1678871397.996:100): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.cache/mesa_shader_cache/index" pid=11147 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[13262.687349] audit: type=1400 audit(1678871398.540:101): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/profiles.ini" pid=11146 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[13262.688504] audit: type=1400 audit(1678871398.540:102): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/secmod.db" pid=11146 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[13262.689008] audit: type=1400 audit(1678871398.544:103): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/cert8.db" pid=11146 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[13262.689018] audit: type=1400 audit(1678871398.544:104): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/key3.db" pid=11146 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[14298.192940] usb 1-1: new high-speed USB device number 3 using ehci-pci
[14298.349619] usb 1-1: New USB device found, idVendor=03f0, idProduct=e111
[14298.349623] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14298.349625] usb 1-1: Product: DeskJet 2130 series
[14298.349627] usb 1-1: Manufacturer: HP
[14298.349629] usb 1-1: SerialNumber: CN74D4C2TN067S
[14298.890147] usblp 1-1:1.1: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x03F0 pid 0xE111
[14298.890185] usbcore: registered new interface driver usblp
[14304.152327] usblp0: removed
[14304.153488] usblp 1-1:1.1: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x03F0 pid 0xE111
[14309.078056] usblp0: removed
[14309.078155] Did not find alt setting 1 for intf 0, config 1
[14309.307980] audit: type=1400 audit(1678872445.185:105): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=3005 comm="cupsd" capability=12 capname="net_admin"
[14311.595924] audit: type=1400 audit(1678872447.473:106): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=3005 comm="cupsd" capability=12 capname="net_admin"
[14416.208831] Did not find alt setting 1 for intf 0, config 1
[14416.413998] audit: type=1400 audit(1678872552.295:107): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=3005 comm="cupsd" capability=12 capname="net_admin"
[14422.610692] audit: type=1400 audit(1678872558.491:108): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=3005 comm="cupsd" capability=12 capname="net_admin"
[14847.739687] audit: type=1400 audit(1678872983.634:109): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=12631 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[14847.741814] audit: type=1400 audit(1678872983.634:110): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=12631 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[14847.800544] audit: type=1400 audit(1678872983.694:111): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=12631 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[14847.802398] audit: type=1400 audit(1678872983.694:112): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=12631 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[14847.804371] audit: type=1400 audit(1678872983.698:113): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/drirc.d/00-mesa-defaults.conf" pid=12631 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[14847.806528] audit: type=1400 audit(1678872983.698:114): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.cache/mesa_shader_cache/index" pid=12631 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[14848.489662] audit: type=1400 audit(1678872984.382:115): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/profiles.ini" pid=12630 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[14848.490819] audit: type=1400 audit(1678872984.382:116): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/secmod.db" pid=12630 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[14848.491357] audit: type=1400 audit(1678872984.382:117): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/cert8.db" pid=12630 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[14848.491365] audit: type=1400 audit(1678872984.386:118): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/christelaurent/.thunderbird/s3gr902z.default/key3.db" pid=12630 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[14975.371871] audit: type=1400 audit(1678873111.265:119): apparmor="ALLOWED" operation="connect" profile="libreoffice-oopslash" name="/tmp/OSL_PIPE_1000_SingleOfficeIPC_988cb793efbfc7847baf6996a628cb9" pid=12678 comm="oosplash" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[14975.371878] audit: type=1400 audit(1678873111.265:120): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oopslash" name="/tmp/OSL_PIPE_1000_SingleOfficeIPC_988cb793efbfc7847baf6996a628cb9" pid=12678 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[14975.371881] audit: type=1400 audit(1678873111.265:121): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oopslash" name="/tmp/OSL_PIPE_1000_SingleOfficeIPC_988cb793efbfc7847baf6996a628cb9" pid=12678 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[14975.371987] audit: type=1400 audit(1678873111.265:122): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oopslash" name="/tmp/OSL_PIPE_1000_SingleOfficeIPC_988cb793efbfc7847baf6996a628cb9" pid=12678 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=1000 ouid=1000
[14975.371990] audit: type=1400 audit(1678873111.265:123): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oopslash" name="/tmp/OSL_PIPE_1000_SingleOfficeIPC_988cb793efbfc7847baf6996a628cb9" pid=12678 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=1000 ouid=1000
[28800.608818] usb 5-1: new full-speed USB device number 3 using xhci_hcd
[28800.813325] usb 5-1: New USB device found, idVendor=2341, idProduct=0043
[28800.813329] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[28800.813331] usb 5-1: Manufacturer: Arduino (www.arduino.cc)
[28800.813333] usb 5-1: SerialNumber: 750333032343518140D1
[28801.608882] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
[28801.611576] usbcore: registered new interface driver cdc_acm
[28801.611578] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
christelaurent@christelaurent-System-Product-Name:~$
...Heu...a l'aide?
