Watch program unable to compile for ATtiny85
i made a small watch program but whenever i try to upload it to my ATtiny85 20PU using Arduino UNO as ISP it stops at compiling and reports:
/home/pi/Downloads/arduino-1.8.13/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: Watch.ino.elf section `.text' will not fit in region `text'
/home/pi/Downloads/arduino-1.8.13/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: region `text' overflowed by 5392 bytes
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board ATtiny25/45/85.
i tried it on my Arduino UNO and it compiled, uploaded and worked fine
i think it may have something to do the Strings created when i do the u8x8.print() command but i'm not sure what to do about that
here is the program (with way too many comments):
#include <U8x8lib.h>
//prepare screen (i'm using a 1306 I2c 128x64 white oled btw)
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(7,5);
//buttons for setting the time
int upButton = 2;
int selButton = 3;
//time variables
int hours;
int minutes;
int seconds;
long last;
//variable for if hours (1), minutes (2), or none (0) is selected
int select;
  //set up buttons
  pinMode(upButton, INPUT);
  pinMode(selButton, INPUT);
  //variable start values
  hours = 12;
  minutes = 0;
  seconds = 0;
  last = millis();
  select = 0;
  //begin screen
  u8x8.begin();
  //loop until a second passes
  while (millis() - last < 1000) {
    //show time on screen
    displayTime();
    //check if the select button has been pressed
    if (digitalRead(selButton) == LOW) {
      //select next time part (hours, minutes, none)
      select ++;
      if (select == 3) {
        select = 0;
    //check if the up button has been pressed
    if (digitalRead(upButton) == LOW) {
      //if select is on hours
      if (select == 1) {
        //increase the hour
        increaseTime(0, 0, 1);
      //if select is on minutes
      }else if (select == 2) {
        //increase the minute
        increaseTime(0, 1, 0);
  //prepare for next second
  last += 1000;
  //increase the second
  increaseTime(1, 0, 0);
//use to show time on the screen
void displayTime() {
  //set font
  u8x8.setFont(u8x8_font_courB24_3x4_r);
  if (select == 1) {
    //make the hours text inverted colors
    u8x8.setInverseFont(1);
  //if not on hours
  }else {
    //do not make the hours text inverted colors
    u8x8.setInverseFont(0);
  //if hours is less than 10
  if (hours < 10) {
    //add a zero before the hour
    u8x8.drawString(1,2,"0");
    //set cursor in position
    u8x8.setCursor(4,2);
  //if hours is more than zero
  }else {
    u8x8.setCursor(1,2);
  //show hour
  //I THINK HERE MAY BE ONE OF THE PLACES THAT IS MAKING IT NOT COMPILE FOR ATTINY85
  u8x8.print(hours);
  //do not make text inverted
  //add colon
  u8x8.drawString(7,2,":");
  if (select == 2) {
    //make text inverted
  //if not on minutes
  }else {
  //if minutes is less than 10
  if (minutes < 10) {
    //add a 0 before minute
    u8x8.drawString(10,2,"0");
    u8x8.setCursor(13,2);
  //if minutes is bigger that 10
  }else {
    u8x8.setCursor(10,2);
  //show minutes
  //I THINK HERE IS THE OTHER PART THAT HAS TROUBLE COMPILING FOR ATTINY85
  u8x8.print(minutes);
//use to increase either seconds (s) minutes (m) or hours (h)
void increaseTime(int s, int m, int h) {
  //increase seconds by s value
  seconds += s;
  //if seconds is 60 or more
  if (seconds >= 60) {
    //reset seconds to 0
    seconds = 0;
    //increase minutes by 1
    minutes ++;
  //increase minutes by m value
  minutes += m;
  //if minutes is 60 or more
  if (minutes >= 60) {
    //reset minutes to 0
    minutes = 0;
    //increase hour by 1
    hours ++;
  //increase hour by h value
  hours += h;
  //if hour is over 12
  if (hours >= 13) {
    //reset hour to 1
    hours = 1;
btw
the bootloader is burned onto the ATtiny and it can run other programs
As it says, the sketch is too big (by 5392 bytes. How large is it when you compile for the Uno?
That's like 2/3tds the size of the flash on the 't85... like... .it's not even close. If you're using the micronucleus/digispark bootloader, that is almost the entire flash.
Your sketch needs to be drastically downsized to fit on a tiny85!
okay thx... on the uno it says it takes 14950 bytes... but i didn't think it was that long...
The '8' in the ATtiny85 means 8k bytes of FLASH. You are using about 15k bytes so almost twice as much. I think you have to get rid of the graphics library. :frowning:
Yeah, you're gonna need a lighter weight display library. The U8 libraries are too big for ATtiny parts.
well when i tried changing the font from _r to _n it uploads successfully but it runs very very slowly is this because of the program size or the library?
Program size and speed are not strongly correlated (in fact you can often trade size for speed and vise versa, ex. by loop unrolling. inlining, etc - all of which can make the binary bigger but faster)
What part of it is slow? response to buttons? Or is the time advancing slowly? (maybe1/16th, 1/8th, or 1/2 of the speed you expect?)
i havnt actually tried the buttons yet but the screen updates slowly (like pixel by pixel) and comparing it to my stopwatch shows the attiny watch wandering about 5 minutes every stopwatch 1 minute
