I try to connect my IR Remote and oled display but when I finish the code it complete uploading when I took a remote and press a button it didn't work. Can someone please help me
Your post lacks information that we need to be able to assist you. Please read the how to get the most from the forum post. The post contains information on what we need to know.
This includes:
Which Arduino board are you using?
Your test code. Please post your well formatted test code in a code block as described in the forum guidelines linked above. Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
Post links to libraries that are not included with the IDE.
Please post a schematic or wiring diagram. Written descriptions are always more ambiguous than a drawing. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
Post data sheets or other technical data for the relevant components.
Photos of the project and the wiring are often valuable.
Sorry I didn't post the code earlier and Dagrem and pin numbers
This is the Code
#include <IRremote.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// declare an SSD1306 display object connected to I2C
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// bitmap of arduino-icon image
const unsigned char ArduinoIcon [] PROGMEM = {
// 'arduino-icon', 128x64px
0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x1b, 0x6c,
0xa4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x1b, 0x6c,
0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x54, 0x1b, 0x6e,
0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x54, 0x1b, 0x6c,
0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x54, 0x1b, 0x6c,
0xa4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x20, 0x11, 0xfe, 0x20, 0x0c, 0x00, 0xf8, 0x1e, 0x08, 0x04, 0x7f, 0x80, 0x00, 0x00,
0x00, 0x00, 0x20, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x04, 0x61, 0x88, 0x04, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x20, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x00, 0x61, 0x8c, 0x0c, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x23, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x00, 0x61, 0x8e, 0x1c, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x23, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x00, 0x61, 0x89, 0x24, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x23, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x00, 0x61, 0x88, 0x04, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x23, 0x11, 0xf0, 0x20, 0x0c, 0x01, 0x00, 0x61, 0x88, 0xc4, 0x7c, 0x00, 0x00, 0x00,
0x00, 0x00, 0x23, 0x11, 0x80, 0x20, 0x0c, 0x01, 0x04, 0x61, 0x88, 0x04, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0x80, 0x30, 0x0c, 0x00, 0x00, 0x00, 0x08, 0x04, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x1c, 0xe1, 0xfe, 0x3f, 0x8f, 0xf0, 0xf8, 0x1e, 0x08, 0x04, 0x7f, 0x80, 0x00, 0x00,
irrecv.enableIRIn();
irrecv.blink13(true);
// initialize OLED display with address 0x3C for 128x64
delay(2000); // wait for initializing
oled.setCursor(0, 0);
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume();
oled.clearDisplay();
// display bitmap
oled.drawBitmap(0, 0, ArduinoIcon, 128, 64, WHITE);
oled.display();
delay(2000);
I am using an Arduino UNO Board
pin Output is
IR Remote:- output pin is 7
Ground pin to Ground
VCC pin to 3.5 volts
Oled display:- Ground-to-ground
Vcc pin to 5V
Scl Pin to A5 pin
SDA pin to A4 pin
anyone help me now
When you run the code, does the display show the bitmap?
What version of the IRremote library have you installed?
Have you made the IR receiver to work with the IRremote library examples?
Hey @groundFungus
The oled display didn't print anything
My IR Remote library version is 3.7.1
It works with IRremote library examples
Do you know the answer
I try to connect my IR Remote and Oled display but when I finish the code it complete uploading when I took a remote and press a button it didn't work.
This is the Code
#include <Wire.h>
irrecv.resume();
// display bitmap
oled.display();
delay(2000);
pin Output is
Vcc pin to 5V
Scl Pin to A5 pin
SDA pin to A4 pin
Can someone please help me?
I have merged your cross-posts @nithums.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I am sorry It was my mistake i will never do it again
@pert - @anon56112670 posted a link concerning the issue (on the other, removed, topic), but the post did not make it to this topic.
@nithums - You can see there is a conflict with IRremote and OLED. After that is resolved, you will need to initialize the OLED so the "BT WELCOME WIFI BATTERY" displays on the OLED... you just need to find out why OLED and IRremote are not working together.
The link you are referring to was a link to the topic we are in now.
Here is what was written:
I intentionally omitted it from the merge because after the merge it was not necessary and would only have caused confusion.
