Hello,
How to connect this to Arduino Please IR TX and RX
I am using this as beam break sensor for around 20" range
Hello,
nothing special. translucent one as normal LED and dark one as input. just try.
How you have connected them, and is it working?
If you think connections should be changed, explain.
What is the environment. A simple IR LED and photo diode does not work well across that distance if ambient light is present. It would be better to modulate that IR LED with an 38kHz carrier, and use a 3-pin IR receiver designed for continuous IR with it, not just a photo diode.
Leo..
Edit: Just saw you had a second thread running for the same project.
Link ?
TSSPxxxx sensor instead of TSOPxxxx.
TSSP4038 is an 38kHz sensor with round lens.
Suitable for beambreak.
Leo..
Yes but not in a totally straight-forward way. That receiver needs to receive 38kHz modulated IR, but that's not what that transmitter creates.
So you would need to modulate the IR yourself; I vaguely recall testing such a thing with the tone() command.
Any alternative suggestions
Either use a receiver that's just a straight ir photodiode, or use a transmitter that produces modulated IR in the first place.
The modulated way will be less susceptible to false readings from spurious transmissions around the place.
Can u suggest one
Not without doing the same search you could do ![]()
Actually, i just had another look at the page of the Grove emitter you linked at the start of the thread, and it says it is often used with the receiver you linked to. So perhaps the Grove emitter does produce 38kHz modulated IR?- it's now not clear (to me, anyway) if it does or if you need to take care of the modulation yourself.
But the Keyes one does specifically say it produces 38kHz modulated all by itself....
I'm pretty sure Keyes also have a receiver module (like the Grove one) so it might be worth looking for that and get a "matched pair" so to speak.
edit... but remember, you don't have to use modulated IR for a break beam, you can do that with a simple IR led and photodiode, unless the circumstances require you to use modulation, eg if the ambience is such that there are false readings, like outdoors for example.
I found these two but I do not have expertise to find out whether this would work for me hence seeking advise. Yes it is for outdoor use
KY-005 38KHz Infrared IR Transmitter Sensor Module
Generic KY-022 Infrared IR Sensor Receiver Module
Well I did a quick search (you didn't give a link...) and found this for that ky022:
.... so it seems that's a suitable pair from one manufacturer.
So I use the following in pair right
One thing I just remembered though, and perhaps others can answer before you commit, is that I know some IR 38kHz receivers are designed for tv style remotes, which send in bursts. They do not remain active for a long never ending stream such as what you would send from your permanently "on" transmitter.
I don't know how to tell if that KY022 is one or the other.
You are very helpful. Yes you are right it is for TV remote. Ideally This one Suits IR Beam Break Sensor but not available in my country, If you figure out what is this, I would prefer to do it myself as it seems simple and meet my criteria
may be these parts are used IR Emitter and Receiver
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Your OS and version can be valuable information, please include it along with extra security you are using.
Always list the version of the IDE you are using and the board version if applicable.
Use quote or add error messages as an attachment NOT a picture.
How to insert an image into your post. ( Thanks @sterretje )
Add your sketch where applicable but please use CODE TAGS ( </> )
Add a SCHEMATIC were needed even if it is hand drawn
Add working links to any specific hardware as needed (NOT links to similar items)
Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
Ensure you have FULLY inserted the USB cables.
Check you have a COMMON GROUND where required. ( Thanks @Perry)
Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
Try other computers where possible.
Try other USB leads where possible.
You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
There may be a problem with the board check or remove your wiring first.
Remove any items connected to pins 0 and 1.
COMPUTER RELATED
Close any other serial programs before opening the IDE.
Ensure you turn off any additional security / antivirus just to test.
There may be a problem with the PC try RESTARTING it.
You may be selecting the wrong COM port.
Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
Clear your browsers CACHE.
Close the IDE before using any other serial programs.
Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
CH340/341 based clones do not report useful information to the “get board info” button.
NANO (Old Types) some require you to use the OLD BOOTLOADER option.
NANO (ALL Types) See the specific sections lower in the forum.
NANO (NEW Types) Install your board CORE’s.
Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
On Linux ~/ArduinoCreateAgent-1.1/config.ini
On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
