Extern pullup resistors needed by bistable-relais-module ?
hi,
i want to switch bistable relais by Arduino nano.
type is SRD-05VDC-SL-C as module, see photo additionally..
in a first realisation using 6 relais for switching model-railway-tracks
the relais switched in a unplanned manner what is strongly forbidden in my situation
the relais-electronic is feed at 5V by the same source as ardiuno.
didnt find any useful documentation for using relay with arduinos.. :roll_eyes:
questions
  1. the trigger-input of relais was directly connected to a digital pin of arduino nano.
    is that correct ?
  2. does the trigger input of relais need pullup-resistors connected to VCC , maybe 4k7 ?
  3. are condensators needed from trigger-pin to ground ?
The above is the part number for the actual relay component on the board rather than the module in the image.
Are you sure that what you have is a latching relay module? The picture you provided looks to be that of a simple on/off relay module. If it were latching, then I would have expected additional components to be visible. Perhaps they are mounted on the underside of the board.
I would be suspicious of that image as the wording says that the relay can handle up to 265VAC but the manufacturers printing on the relay itself says only 250VAC.
Please post a link to the product page for the relay module you have.
link wanted : i´ll search for this..
mesanwhile here´s the code used to trigger
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(led_red, OUTPUT);
  pinMode(led_yellow, OUTPUT);
  pinMode(led_green, OUTPUT);
  pinMode(pin_digi_bistab_rel, OUTPUT);
  digitalWrite(led_red, LOW);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(led_green, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(led_yellow, LOW);
  digitalWrite(pin_digi_bistab_rel, HIGH);  //- FlipFlop of Relais needs negative Impulses !
// the loop function runs over and over again forever
  digitalWrite(led_red, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(TIME_TEST_LOOP);                       // wait for a second
  digitalWrite(led_red, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(led_yellow, HIGH);    // turn the LED off by making the voltage LOW
  digitalWrite(led_yellow, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(led_green, HIGH);    // turn the LED off by making the voltage LOW
  Serial.println("..new pulse");
  send_pulse();
void send_pulse()
  digitalWrite(pin_digi_bistab_rel, LOW);
  delay(30);
  //delay(30);
  //digitalWrite(pin_digi_bistab_rel, LOW);
Some magic booster? :smile:
That relay is not bistable, some circuit on the module can mimic that behavior though.. And your code is quite exotic to drive any relay...
Chinese volts are more gentle :sweat_smile:
  1. It depends how much current the coil needs.
  2. What trigger?
  3. See 2.
What voltage are you switching?
I found another view of that relay module and there's a small 4-pin SIL device just to the right of the relay body. I guess that takes care of the latching process.
Wanna bet it's rated at 15 VAC? :smirk:
@lupus51 are you using a PWM output to drive/toggle the relay? Isn't PWM way too fast for a mechanical relay. Post all your code.
its 7 to 12 Volt DC with extern PWM-speed-regulating totally separated from the arduino
i`m sorry for the first sketch - but tried this version too -
now the sketch for directly switching from ardiuno is inserted
the relays were buyed from ali..
  • Why are you needing latching relays ? :thinking:
I believe you are in for a lot of long nights if you consider that a latching relay. Per the data sheet is is a pseudo standard form C relay with a 5VDC coil, 0.36W. The latching function can be implemented with additional circurity on the board but when the power goes away the the contacts will revert to the normal position. The NC contact will close and the NO will open.
I recommend to buy a latching relay instead.
Never considered switching using transistors? You can put together the components yourself, or get a module.
As a follow up to my post #9, here's an image of what I think is the OPs relay module from a different angle:
There appears to be a small device - 4 pins according to other views of the same module - that likely handles the latching.
As has been previously asked, why do you need a latching relay module rather than a standard on/off relay module?
hi,
i want to have stable status at trains supply and assumed this
could only guaranted by my choice..
but :
who answers my questions ?
At least reading the specification again
i will measure temparature at
High-Status to see wether coils heats too much
gather,that must not be over 60 degrees celsius ?
  • Using software, a couple lines of code can turn regular relays into latching devices.
    You can even save latched states thru a power off condition by writing a relay’s state to EEPROM in the Arduino.
Example
There are a lot of 8 channel relay modules available that look similar to this.
