Help about print negative pattern using eagle
hello every one
i dont know if this is the correct place for my topic .
my issue is i want use eagle instead of proteus isis for trace my board because there are some limit and some problem about hole (proteus isis can't trace flat hole have only round one)
and on other hand eagle get more realistic board i guess that because it responsible only for design board .
i print the pattern directly to my own printer into transparent paper like this by proteus :
on the eagle the only way that i find when i search on the software is generating CAM gerbel and select the part need to be negative .
someone her can get me some solution
It is not.
warning DO NOT CREATE TOPICS IN THIS CATEGORY warning
Maybe flag this and ask a moderator to move it to the General Discussion section.
This is the Arduino forum not the Eagle forum. You will probably get an answer faster there.
Sorry, but what exactly is your question?
Thank's i moved it
How to print negative pattern directly using eagle software
that was my problem too. now i using EasyEda.com and forgot Eagle for 3-4 years until today.
i print the PCB to PDF then extracted image with big resolution, invert it, put it to Inkscape and convert bitmap to path.
... or look at KiCad, that's what I use.
Google says: Google Search
There doesn't seem to be a way to print negative images directly; the usual suggestion is to "export image" and then manipulate with graphics program, or use the CAM processor to generate PS_INVERTED
How to export inverted pattern pdf or image from cam proccessor
The iterrested part of eagle is the realistic of the treaces is verry fine and the default pad is verry good look this board for fusebit doctor available on internet i build it it verry nice
Even the sace betwen trace low i doesn't have anny issue
