i get confused about the difference between footprint and packaging?
there are known packaging such as
SOT-223:
and their PCB footprint code is also SOT-223:
so what is the difference?
and for example, if i need to know the PCB footprint of this device:
how shuld i name the PCB footprint and the Packaging?
"Description IC REG LDO 3.3V 0.8A SOT223 "
So call them SOT223.
Is this for Eagle? You can often look in the Burr-Brown section, find REG1117 in SOT223 package, confirm the GND-Out-In pinout matches, and use that. On the schematic, right click and Name it TLV1117-33CDCYR so it shows up correctly when you create Export a Parts List.
CrossRoads:
i use OrCAD and there is a place where i need to input PCB footprint for all symbols,
SOT223 isn't enough? and please explain why
is it because pin1 and pin4 (vout) are the same?
i just in the stage of creating the schematic something like this (for example):
i need to send this to someone who will use allegro for PCB design and this is the information that he need to create the board.
I'm not familiar with Orcad/Allegro.
